Go Back   Home > Forums > General Interest > Car Audio
Old 28th May 2012, 06:01 PM   #1
DREW028 is offline DREW028  United States
Send a message via AIM to DREW028
Default earthquake phd2
I pulled all the PS transistors and I'm getting 13v on the gates. Ic5 and ic8 are defaced. I do have a 200dhc still that has a sg3525an in ic5. If they are the same chip here are the readings. Do they seem right? What could ic8 be?
Ic5
Pin 1: .099
Pin 2: 5.1
Pin 3: .018
Pin 4: .119
Pin 5: 2.06
Pin 6: 3.88
Pin 7: 2.06
Pin 8: 4.83
Pin 9: 5.7
Pin 10: .112
Pin 11: 6.38
Pin 12: .015
Pin 13: 13.51
Pin 14: 6.38
Pin 15: 13.51
Pin 16: 5.1
Old 28th May 2012, 08:59 PM   #2
MIC4424 or TC4424
Old 29th May 2012, 02:27 AM   #3
Correct me if I'm worng please. As far as the pin lay out the only difference is the #6 pin. I've been trying for figure which ic this is. Pin 6 of ic8 connects to Pina 15 and 13 of ic5. Would this make it the tc4424?
Ic8 readings
Pin1: 0
Pin2: 6.3 (pulse)
Pin3: .012
Pin4: 6.37(pulse)
Pin5: 12.6
Pin6: 13.51
Pin7: 13.27
Pin8: 0
Old 29th May 2012, 04:35 AM   #4
Those two ICs are the same other than the manufacturer.
Flickering headlights with an earthquake phd2 Sinister7 Car Audio 9 26th February 2012 11:12 PM
Earthquake PHD2 Hectorscaraudio Car Audio 1 14th November 2011 10:10 PM
Earthquake PHD2 seems to lower output??? ppia600 Car Audio 94 14th November 2011 07:46 PM
Earthquake PHD2 amp fongman Car Audio 7 3rd June 2010 05:58 PM
Earthquake D200hc/phd2 modification? spooney Car Audio 32 19th March 2010 03:51 PM
Page generated in 0.27727 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
