TMA T1000.1  Rev. 2.0 Board
Old 26th May 2012, 03:42 PM   #1
RiLoWa is offline RiLoWa  United States
RiLoWa's Avatar
Default TMA T1000.1 Rev. 2.0 Board
This amplifier is missing a couple of capacitors, C322 & C323. Does anyone know what values belong there?
Tools - 1. TPI Scope Plus 440 2. B&K 2125 20MHz Dual Trace 3. Sorensen DCR20-50B 4. B&K 4011 5MHz Function Generator 5. Weller WESD51 6. A big hammer
Old 20th June 2012, 02:35 AM   #2
RiLoWa's Avatar
I have temporarily installed some 100uF, 16 caps in those spots.
The next problem I am having with it is pins 8 & 11 of the 594 only have .127 VDC on them with remote voltage applied. All of the other pins look like it should be powering up fine. The first two pictures show the general area around the 594 and the third shows the path, in red, of what I find connected. Pins 8 & 11 are connected to the collectors of the two D667 drivers and to the zener diode labelled ZD301. I think that I am missing a resistor located at R314 above that zener diode as the circuit just ends like shown in red. I don't see how 12VDC could ever be on those two pins without it. I measure B+ voltage on the pad opposite the one connected to ZD301 when remote voltage is applied.
As a temporary test, I applied 12VDC to pins 8 & 11 by shorting pin 11 to pin 12. The amp powers up and will play audio, but the protection LED is also lit. I realize that Pin 12 is probably not capable of delivering the current required for pins 8 & 11 and the collectors of the drivers, it was just a brief test and the short has been removed.
Can anyone advise what value should be installed there?
Old 20th June 2012, 07:44 AM   #3
Perry Babin is offline Perry Babin  United States
If one end of R314 has 12v on it and the other end is directly connected to pins 8 and 11, it would appear that a resistor is missing in that location.
Old 22nd June 2012, 03:08 AM   #4
RiLoWa's Avatar
I placed a 150 Ohm, 1W resistor in there and found the 1N4741 zener was defective as it only had ~4.5V across it.
I replaced it with a smaller wattage 12V zener that I have on hand and the amplifier powered up and played audio fine, but I only measured ~8.5VDC across the newly installed zener.
I replaced the 150 Ohm resistor with a 10 Ohm 2W resistor in that location and I now have ~12VDC across the diode and at pins 8 & 11 of the 594. I have ordered the correct zener and will install that when it arrives.
TMA T1000.1  Rev. 2.0 BoardHide this!Advertise here!
TMA T1000.1 mike49504 Car Audio 1 12th May 2012 04:03 PM
Aleph X rev 1 Board for sale bqc Swap Meet 1 16th April 2012 07:02 AM
FS: IRAUDAMP1 Rev. 4.1 Eval Board theAnonymous1 Swap Meet 3 3rd May 2008 02:51 AM
WTB: Dynalo Rev. C Board colonelkernel8 Swap Meet 0 6th November 2007 03:41 AM
Sonic Impact T-amp Rev D Board HELP!! Jazute Class D 5 8th September 2007 03:11 PM
