Punch 300s - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 25th May 2012, 09:55 PM   #1
Default Punch 300s
I dont think theres alot of problems with this one. I think a ground wire was hooked up to the remote lead and ruined the turn on circuitry. I can run power to it and no smoke or excessive heat. The transformers warms to and idle temp but no light comes on. The voltage on Q6 and Q7 are from left to right
Q7 MTP75N05HD Q8MTP75N05HD
pins
1. 13.03v 1. 12.09v
2. 13.20v 2. 13.16v
3. 0v 3. 0 v
Old 25th May 2012, 10:47 PM   #2
Those transistors are blown.
Old 25th May 2012, 10:48 PM   #3
okay so I replace them? is there a suitable substitute as I have somecomponents laying around
Old 25th May 2012, 11:05 PM   #4
I'd use IRF3205s.
If the gate resistors are out of tolerance (you'll have to remove the FETs before you can check the resistors), use 47 ohm replacements.
You'll also need to check the driver transistors.
You need to replace all of the power supply FETs.
Old 25th May 2012, 11:12 PM   #5
driver transistors are Q5,Q1,Q2,Q4? coming off TL494 feeding the irfz40?
Old 25th May 2012, 11:45 PM   #6
seankane's Avatar
Yes they are marked 1A and 2A replace all 4.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 27th May 2012, 04:27 PM   #7
Havent checked the transistors yet as Im not home(away from schematic) but what is the model number of the transistors Q5,Q4, Q1,Q2 ?
Old 27th May 2012, 04:55 PM   #8
Tracked down the schematic ok bt3904's on the high side bt3906's on the lowside of each pair. Mr. Babin the schematics show IRFZ40's I have some Z44's will they work?The 75N05HD which are whats on the amp now have that HD- is that heavy duty? Are they possibly more robust than z40's or your suggested IRF3205's? I appreciate all the help. I guess I need not to be so lazy and do an ac/dc analysis of the circuit which would tell me what I should see at any node. Very time consuming. I guess if Im really lazy I could redraw the circuit in multisim and really play around with that to see what will work.
Perry you deserve a medal for saving folks all that time and effort on repair- nothing like real world experience!
Thank you very much.
Hugh.
Old 27th May 2012, 08:07 PM   #9
Z44s = less reliable
3205s = more reliable
Old 29th May 2012, 12:53 PM   #10
R20 is 69 ohms
R19 is 68.7 ohms
BASH 300S Blowing Fuses cheryl Subwoofers 3 21st February 2017 04:37 AM
Krell KSA-300S will not turn on fcel Solid State 54 26th March 2015 03:01 PM
Rockford Fosgate 300S mike49504 Car Audio 2 29th April 2012 06:10 AM
Selling a punch 250a2, old punch 75, and ppi epx 205 on EBAY ppia600 Swap Meet 0 23rd February 2008 01:17 AM
My experience: the cheap punch set VS Greenlee punch vax9000 Tubes / Valves 5 21st July 2006 07:52 PM
Copyright 1999-2017 diyAudio
