Go Back   Home > Forums > General Interest > Car Audio
Old 24th May 2012, 02:21 PM   #1
Default earthquake ph120.3 in protection mode
hello everybody, i have been reading here for a while, this is my first post here. i have an earthquake ph-120.3 amplifier which is stuck in the protection mode even with all speakers removed, rca cables unpluged. i metered the speaker outputs and there is a reading of +- 4v on there. any help would be great!
Old 24th May 2012, 03:05 PM   #2
If no one can help, post a photo of the inside of the amp.
Old 28th May 2012, 03:23 PM   #3
hi Perry , sorry about the late reply,here is a picture of the board. many thanks
Old 28th May 2012, 09:01 PM   #4
Is it still going into protect mode with the output transistors out of the circuit?
Old 28th May 2012, 09:28 PM   #5
hi there, yes it is, a day before it shut down there was a humming sound coming from the amp.
Old 29th May 2012, 04:43 AM   #6
Check Q510 and the corresponding transistors in the other channels.
What is the IC that's been replaced in the power supply?
Old 30th May 2012, 09:01 AM   #7
hi there, i checked the transistors and these are the readings as follows:
1.638.1 ohms 1. 0.634 diode test
2.513.6 2. 0.518
3.ol 3. ol
4.ol 4. ol
5.512.7 5. 0.517
6.601.9 6. 0.607
these readings were very similiar for all six of them, used your method for testing smd transistors. the ic is a 8 pin one,has a number on it: 358A, i tried to remove it thats why it looks like that. the power supply fet's only have +13v on the centre leg. output transistors have +3.8v on all legs. i checked power supply fet's and found one faulty one. many thanks
Old 30th May 2012, 11:47 PM   #8
help from anyone would be appreciated .
thanks in advance.
Rakshark
Old 31st May 2012, 04:50 AM   #9
Post the DC voltage on all pins of the LM358 and the TL494. Copy and paste the following into your reply. Place the black probe on the amplifier's ground terminal.
LM358
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
TL494
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Old 31st May 2012, 11:02 AM   #10
LM358
Pin 1: 8.70
Pin 2: 8.93
Pin 3: 8.40
Pin 4: 0.002
Pin 5: 5.17
Pin 6: 9.42
Pin 7: 0.008
Pin 8: 10.36
TL494
Pin 1: 0.240
Pin 2: 7.92
Pin 3: 0.242
Pin 4: 0.024
Pin 5: 3.106
Pin 6: 6.69
Pin 7: 0.002
Pin 8: 12.71
Pin 9: 0.001
Pin 10: 0.001
Pin 11: 12.70
Pin 12: 10.36
Pin 13: 8.43
Pin 14: 8.43
Pin 15: 8.43
Pin 16: 8.00
kind regards.
Nad 304 Protection Mode sirhenry Solid State 2 14th May 2009 09:46 AM
amp protection mode ? chrissy14xsi Car Audio 40 14th March 2009 02:00 AM
Amp Protection Mode sseabrook07 Car Audio 3 29th October 2006 02:26 PM
denon receiver going to protection mode Anfield Solid State 12 7th September 2006 04:21 PM
protection mode won't go off Darkcrusher Solid State 5 2nd February 2006 02:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
