Rockford Fosgate BD1000
Old 24th May 2012, 07:20 AM   #1
seankane is offline seankane  United States
seankane's Avatar
Default Rockford Fosgate BD1000
Hello everyone.
Recieved this amp and it wouldnt power on just blow the fuse.
I replaced 6 of the output fets that were shorted.
With no input connected the amp powers up fine and idles fine.
The drive circuit for the power supply looks good on the scope and the gate signal on the outputs fets looks good as well.
There is -13.95 on the speaker output terminal.
When a signal from the head unit is applied the amp lets out a very loud buzzing noise.
I am suspecting maybe U17
U17 reads as follows:
Pin1: -0.018
Pin2: -0.005
Pin3: -13.86
Pin4: -23.55
Pin5: -0.003
Pin6: -13.86
Pin7: -4.10
Pin8: - 0.003
Why the -23.55 on pin 4?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 24th May 2012, 12:16 PM   #2
brandes.cm is offline brandes.cm  United States
You must have bad/leaky outputs with dc out there. Is the amp in protect? If not check U21.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 24th May 2012, 01:45 PM   #3
Perry Babin is offline Perry Babin  United States
All of the voltages are shifted down by 13.86v. Are you sure that you didn't have the black probe on the B+ terminal?
Old 24th May 2012, 09:10 PM   #4
seankane's Avatar
Yes I did have the probe on the B+ terminal.
There is no voltage on the output terminal.
Since the amp powers up and idles fine and does not go into protect I am going to have to assume that the problem is in the input stage.
As soon as you hook up a signal the amp starts buzzing like crazy.
Why the -23.55 volts on pin 4 of U17?
Old 24th May 2012, 10:20 PM   #5
With the black probe on the amp's ground terminal, do you still read -23 on pin 4?
Old 25th May 2012, 01:54 AM   #6
seankane's Avatar
No.
Pin4: -9.75 vdc
Pin7: 9.75 vdc
The rest of the pins have minimal voltage on them.
Old 25th May 2012, 02:08 AM   #7
This is normal.
Rockford Fosgate BD1000Hide this!Advertise here!
Rockford Fosgate BD1000.1 jandar Car Audio 11 22nd June 2013 12:43 AM
Rockford FOsgate BD1000 seankane Car Audio 30 2nd January 2012 04:48 AM
Rockford Fosgate BD1000 seankane Car Audio 133 1st April 2011 07:57 AM
rockford fosgate BD1000 mike49504 Car Audio 73 10th February 2011 07:05 PM
Rockford Fosgate BD1000 mike49504 Car Audio 1 9th January 2011 12:37 PM
