mtx thunder 5601 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 23rd May 2012, 05:36 AM   #1
Default mtx thunder 5601
so as the title says, i have a mtx thunder 5601 and it wont power on. it worked for about a week then just shut off, i know all the connections to the amp where good cuz i hooked up my backup amp and it worked with no problems.
all 3 25amp fuses checked good, i opened it up and didnt see anything that looked burnt. i had no thermal or short lights on.
just wondering what would be a good area of the amp to start my t/s with. im guessing some kind of power transformer/ transistor.
Old 24th May 2012, 12:32 PM   #2
Post a pic of the board and start checking the supply and output devices.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 24th May 2012, 02:04 PM   #3
Post the DC voltage on all pins of the IC indicated in the attached photo. Place the black probe on the ground terminal of the amplifier. The arrow is pointing to pin 1. Look at the other photo to see the numbering scheme. Copy and paste the following into your reply. Remove the fuses and insert a 10 amp fuse in place of one of the fuses. This will help protect the amp if you make a mistake. If you haven't done so already, read the basic amp repair page (link in sig line below).
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Old 25th May 2012, 02:51 AM   #4
Old 26th May 2012, 12:09 AM   #5
Pin 1: 2.4v
Pin 2: 2.4v
Pin 3: 3.4v
Pin 4: .82v
Pin 5: 1.5v
Pin 6: 3.3v
Pin 7: .7v
Pin 8: 12.18v
Pin 9: .7v
Pin 10: .5v
Pin 11: 12.39v
Pin 12: 13.12v
Pin 13: 4.95v
Pin 14: 4.95v
Pin 15: 4.9v
Pin 16:.5v
Old 26th May 2012, 06:28 AM   #6
The power supply appears to be operating. What is the DC voltage on pins 4 and 8 of the op-amp near the RCA jacks?
Old 27th May 2012, 06:42 PM   #7
got any idea what c119 would effect, it fell off the board today and what would be a part number to replace it.
all i can see on the top is in the following order
10
25s
4cd
Old 27th May 2012, 09:13 PM   #8
Capacitors don't simply fall off of the board. Did it overheat and melt the solder or was it forcibly removed from the board?
Old 28th May 2012, 01:07 AM   #9
i was looking for the op-amp near the rca's and noticed it was loose so i grabbed it and it came off, i might have broke it, but i originally didn't apply any force to it.
Old 28th May 2012, 01:43 AM   #10
10Uf, 25v
MTX Thunder 5601 mike49504 Car Audio 3 15th April 2012 02:27 AM
MTX Thunder 5601 burnt CobraTom Car Audio 5 19th January 2012 12:21 PM
MTX Thunder 2300 spooney Car Audio 59 11th August 2010 01:52 AM
MTX 5601 Amp Help Please Kmazzeo26 Car Audio 3 2nd June 2010 09:51 PM
Any help with MTX 5601 amp? Jorel Car Audio 1 31st March 2010 07:35 PM
Copyright 1999-2017 diyAudio
