punch 45.2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 19th May 2012, 11:39 PM   #1
Default punch 45.2
The TL494 has 21.01v on pin 8,11 and 12 any idea what could cause it to be so high? Rail voltage is + - 21.22v.
Old 20th May 2012, 02:43 PM   #2
Most of the Rockford amplifiers use the output of the 15v regulator to boost the drive voltage for the power supply. If the regulator has failed, that could cause excessive voltage to be present on the 494.
Old 20th May 2012, 05:58 PM   #3
I get 14.08 + - on all opamps so i think the regulators are ok.
Old 20th May 2012, 07:31 PM   #4
The 494 is fed by two sources (on most Rockford amps). The initial input is from the remote terminal. After the switching power supply is up and running, the 15v regulator feeds the IC to boost the voltage and ensure that it remains steady. If the voltage isn't being driven too high by the regulator, it would almost certainly have to be from the remote input terminal. The problem is... the voltage on the remote terminal is monitored and if the voltage goes above about 16v, the amp should shut down.
If you can't find the fault, post the DC voltage on all pins of the LM339 and the 494 as well as the voltage on the B+ and remote terminals.
Old 20th May 2012, 10:30 PM   #5
Light blup in line for limiter.
IC#494
Pin 1: 2.18
Pin 2: 2.17
Pin 3: 3.43
Pin 4: .00
Pin 5: 1.45
Pin 6: 3.27
Pin 7: .00
Pin 8: 21.02
Pin 9: .15
Pin 10: .15
Pin 11: 21.02
Pin 12: 21.02
Pin 13: 4.82
Pin 14: 4.82
Pin 15: 4.83
Pin 16: .00
IC 339
Pin 1: 4.88
Pin 2: 4.88
Pin 3: 21.01
Pin 4: .52
Pin 5: 2.74
Pin 6: 4.66
Pin 7: 4.82
Pin 8: 4.82
Pin 9: 5.28
Pin 10: 4.82
Pin 11: 8.77
Pin 12: .00
Pin 13: 4.88
Pin 14: 21.64
Gnd to Remote 14.71
Gnd to B+ 14.71
Old 20th May 2012, 11:24 PM   #6
I think that's normal for this amp. I don't have this schematic diagram but the 100a2 seems close and it takes the boost voltage from the rails instead of from the regulator. There are only a few amps that do this. The rest take the boost voltage from the regulators. Email me if you want a copy of the 100a2 diagram.
Transistors for punch 45 chipper Car Audio 1 6th March 2012 03:53 PM
PUNCH 45 2ND GEN NON HD seankane Car Audio 4 22nd November 2011 12:57 AM
Rockford fosgate punch 45 no output chipper Car Audio 37 18th October 2011 06:25 AM
Punch 45 - Weird Problem with Start-up bigphil Car Audio 5 30th December 2008 07:59 AM
Looking for Part for old Punch 45 TP3055A shimp Parts 13 15th May 2006 10:18 PM
Copyright 1999-2017 diyAudio
