Memphis 16-PR1KD Over-Current triggering - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 16th May 2012, 06:38 PM   #1
Default Memphis 16-PR1KD Over-Current triggering
Hello,
Working on a Memphis 16-PR1KD. A few months ago I replaced all the audio output drivers & associated parts that were overheating, but after testing, on certain peaks the Over-Current protection triggers. Definitely should not be going into over current when it does.
Otherwise the amp plays fine even at high power into a 1-ohm (speaker) load, clean solid output, just certain kick drums & low freqs trigger the over current, not even pushed quite to clipping sometimes. If I recall, it even did it when wired to 4-ohm.
The only substitutions I made were as follows: (could this be an issue or should I look further into the protection circuit?)
Q18 & 19: original C3200, I installed 2SC2240ís
Q33: original C3227, I installed a BC639
Q21: original A1275, I installed a KSA1220A
Any info on this would be appreciated, thank you.
Old 16th May 2012, 07:24 PM   #2
If you can't find the fault, post the voltage on all pins of the comparator, using pin 4 as the reference (black probe).
Memphis 16-PR1KD RiLoWa Car Audio 19 15th May 2012 08:58 AM
Memphis 16-PR1KD amp repair help (pix) raverx3m Car Audio 15 24th April 2012 09:07 AM
Memphis 16-PR1KD timwebb Car Audio 13 6th July 2010 11:13 PM
problem with my amp memphis 16-pr1kd pollo1008 Class D 0 29th December 2009 11:20 PM
memphis 16-pr1kd chev55_steve Car Audio 0 2nd January 2009 11:46 AM
Copyright ©1999-2017 diyAudio
