zeus vii - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 16th May 2012, 02:29 AM   #1
DREW028 is offline DREW028  United States
Send a message via AIM to DREW028
Default zeus vii
Amp has no output. 1 of the rca inputs reads 14.3v. I traced the lead back to the c4570c op amp
Pin 1: 15v
Pin 2: 4.6
Pin 3: .082
Pin 4: -.010
Pin 5: 0
Pin 6: 15.01
Pin 7: 15.3
Pin 8: 16.4
UPC4570C datasheet pdf datenblatt - NEC - DUAL ULTRA LOW-NOISE,WIDEBAND,OPERATIONAL AMPLIFIER ::: ALLDATASHEET :::
Old 16th May 2012, 06:04 PM   #2
Pin 4 should have -15v.
I'm assuming that this is IC1.
Old 16th May 2012, 06:37 PM   #3
Sorry, its right under the gain adjustment.
Old 16th May 2012, 07:08 PM   #4
That's IC1.
Old 16th May 2012, 08:33 PM   #5
The amp is not in front of me but what does pin connect to?
Old 16th May 2012, 08:39 PM   #6
Pin 4 goes back to the negative 15v regulator. ZD2 may be shorted.
Old 17th May 2012, 12:41 AM   #7
Zd2 was shorted. Random failure?
Will the V- always be the same as the V+ for an op amp? Meaning if V+ is +12 can V- be -6v? Or does it depend on where and how its used?
Thanks for your help again.
Old 17th May 2012, 01:23 AM   #8
When run from split supplies, they will be close but there's always a slight difference.
Not all op-amps are run from split supplies. Some have their negative power supply terminal connected to ground and will have supply voltage on the positive supply terminal only. This is common in head units, budget signal processors and class D amplifiers that use the HIP4080 driver IC.
Hifonics Zeus VII warpedhifi Car Audio 9 9th October 2012 02:37 AM
FS: OLD SCHOOL HIFONICS ZEUS VII ernie cosillos Swap Meet 6 30th May 2012 02:51 PM
hifonics zeus vii mike49504 Car Audio 6 30th April 2012 06:31 PM
fs:hifonics zeus vii ernie cosillos Swap Meet 1 5th July 2011 06:41 PM
Hifonics Zeus VII redimp Car Audio 1 20th December 2006 11:47 PM
Copyright 1999-2017 diyAudio
