would someone be able to give me some guidence fixing this orion amp?
Old 12th May 2012, 10:10 PM   #1
chevellebbc is offline chevellebbc  United States
Default would someone be able to give me some guidence fixing this orion amp?
its an orion xtr pro 2400, i sold the amp and the guy blew mosfets.
i've done very minor work with this type of thing in the past and was hoping i could figure it out.. but i cannot lol
i've removed all the fet's (8) on each side. i cannot find what is wrong besides the fet's. when i slightly tap the new fet inplace it arc's. (i think it would blow if it were placed there etc.) i put an old one in it doesnt arc but the the voltage on the gate resistor jumps to 12 volts. isn't is supposed to be under 5 volts etc. also there is a small board mounted veritcally. on that board on the very bottom where it attaches to the main board the two prongs (soldered) gets hot even without any of the fets attached. all the gate resistors read 4 volts. where they attach to the fet. i havent removed any to check the ohms. i really dont know if im jumping steps just doing what i can without distroying something else..
thanks in advance to anyone who may help
Old 12th May 2012, 10:22 PM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I would check for shorted mosfets first.
Even if you find them faulty there could be problems with the driver circuit.
I would check the driver circuit transistors too.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 13th May 2012, 12:40 AM   #3
Thanks for the reply, where would I find the driver circuit transistors. About 6 mosfets were blown out of the 16. I did remove them all.
Old 13th May 2012, 12:57 AM   #4
Old 13th May 2012, 01:07 AM   #5
DREW028 is offline DREW028  United States
Send a message via AIM to DREW028
If you interested in repairing your amp I'd recommend reading this
Basic Amplifier Repair
Unless someone has a schematics for you amp you will have to trace back where the signal for the gates are coming from. You might be able to visually do this or ohm it.
Have you checked the output transistors?
would someone be able to give me some guidence fixing this orion amp?Hide this!Advertise here!
fixing Orion GS1000 Bom Car Audio 4 27th December 2008 03:58 AM
General guidence building guitar amp mashaffer Instruments and Amps 16 5th December 2007 09:54 PM
Help please, some guidence on which dac to keep georgehifi Digital Source 1 3rd May 2005 04:32 AM
Can anyone give more info on this amp? mg16 Tubes / Valves 6 8th May 2003 12:43 AM
Copyright ©1999-2017 diyAudio
