earthquake 200dhc - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 11th May 2012, 12:21 AM   #1
DREW028 is offline DREW028  United States
Send a message via AIM to DREW028
Default earthquake 200dhc
I've got three of these amps with no ouput and look like they've been fixed before ( power supply for sure and near the input). Does anyone have a service manual?
Old 11th May 2012, 01:06 PM   #2
I probed the rca inputs and it seems im getting some kind triangular sine wave ( with out any actual inputs plugged in).
This thread will only refer only 1 of the 3 amp i have
Old 11th May 2012, 01:27 PM   #3
What were the scope settings?
It's probably just noise.
Old 12th May 2012, 02:18 AM   #4
.5v 20ms. I will post a screen shot if it helps. I am still learning about my scope.
Old 12th May 2012, 03:53 AM   #5
I don't think it's anything to be concerned about. Drive a signal into it and see where it stops.
Old 12th May 2012, 04:36 AM   #6
Well I took apart the amp completely and apparently who ever worked on this amp( major repairs have been done) broke the trace and installed a 15 amp fuse between the inductor and the output.
Should I replace with same fuse or fix the trace?? I'm guessing leave it but is 15 amp enough?
Old 12th May 2012, 05:17 AM   #7
The fuse size is generally printed near the fuse holder. For the best protection, you should use the lowest rated fuse that doesn't blow under normal operating conditions.
If the trace was burned, you need to repair it. Sometimes, traces are cut at the factory but it's relatively rare.
Old 12th May 2012, 01:30 PM   #8
Just to be clear the fuse was installed between the + speaker terminals and the inductor.
Old 12th May 2012, 07:12 PM   #9
One or both of the transformers have a buzz to them. That could be the noise on the inputs?
Is this likely cause by the transformer or something causing the transformer to do this.
Old 13th May 2012, 02:32 AM   #10
On this amp someone added that board to the ic. Also added caps and resistors in parallel to the circuit. One of the other amps has the added caps but not the board or resistors.
Earthquake PH2000 mike49504 Car Audio 21 4th May 2012 05:50 AM
earthquake 200dhc power supply repair ivkata Car Audio 1 18th April 2012 09:54 AM
Earthquake 200dhc with hum in output spooney Car Audio 23 27th November 2010 09:15 PM
Earthquake UHC2020 Puggie Car Audio 0 2nd August 2006 10:09 AM
-:- Earthquake -:- audioPT Subwoofers 3 30th October 2004 02:02 PM
Copyright 1999-2017 diyAudio
