Replaced all of the power supply fets,gate resistors, drivers, and outputs..
With R36 removed the amp will power up and produce clean output..
But the amp will make the needle on my power supply bounce around a lil..
If I put R36 (100 ohm) that sits directly behind the transformer back in the amp the amp will draw excessive current and burn the resistor up..
Any ideas ?
Any ideas ?
- General Interest
- Car Audio
- Kicker 750.1
