US Amps 3d - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 10th May 2012, 01:29 AM   #1
timwebb is offline timwebb  United States
Default US Amps 3d
anyone have a schematic for this amp? some traces burnt and someone jumped them to other spots. i need to make sure it right before i go any further. thanks.
Old 10th May 2012, 02:26 AM   #2
Have you tried RE Audio?
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 12th May 2012, 02:11 AM   #3
im waiting to hear back from them. i found the voltage regulators were shorted across and two op amps got hot.would a bad op amp blow the voltage regulators?
Old 20th May 2012, 03:46 PM   #4
ok the dont give there schematics to no one i guess. the amp seems to have a problem with the voltage regulators. the 78 and 79 were shorted across all legs. i pulled the op amps. they are shorted across pins 1 and 8. just trying to see make sure im testing it right.
Old 20th May 2012, 07:35 PM   #5
Out of the circuit, if you read 0 ohms between the pins you listed, the components are defective.
Old 20th May 2012, 08:00 PM   #6
i wanted to be sure cause every op amp reads 0 ohms across pin 1 and 8. all are out of circuit.
Old 20th May 2012, 08:18 PM   #7
What is the number on the op-amps?
Old 20th May 2012, 08:36 PM   #8
4558 the pins are in line. i couldnt find the right data sheet for it.
Old 20th May 2012, 11:27 PM   #9
Those are not 1 and 8, those are 1 and 9. The ICs have 9 pins. This is normal. They allow you to pass positive supply voltage through the IC which helps with tight layouts.
Re-read the audio troubleshooting page, item #15.
US Amps md 3d timwebb Car Audio 20 5th September 2015 11:40 AM
3D Pic... you need Anaglyph 3D Glasses to view moe29 The Lounge 13 18th June 2013 12:56 PM
Resonace and 3D sketchyphish PA Systems 4 25th March 2012 04:52 AM
Eagle in 3D nickgreek Everything Else 2 4th November 2003 11:21 AM
Copyright 1999-2017 diyAudio
