autotek mm 2000.1d
autotek mm 2000.1d
Old 6th May 2012, 09:18 PM   #1
DREW028 is offline DREW028  United States
Send a message via AIM to DREW028
Default autotek mm 2000.1d
I'm not getting a signal from the p.s driver board. Q7 and q8 marked BE EW are BCX55?
Old 6th May 2012, 09:37 PM   #2
Nevermind. After reinstalling the board it works now. Weird.
Old 6th May 2012, 10:04 PM   #3
After I put it back together it wouldn't turn on. If I would press down on the transform closest to the power input the protect light would light up. I flipped the amp over and it started to work again ???????
Old 7th May 2012, 12:55 AM   #4
nonprof is offline nonprof
please check for the cold solder...PWM IC and other nearby components.
Old 7th May 2012, 01:03 AM   #5
timwebb is offline timwebb  United States
i have this same amp. do u know what transistor controls the relay?
Old 7th May 2012, 03:53 AM   #6
I'm not sure. I put it back together. I do notice as soon as the relays click the top pins of q5 and the transistor to the left drops from 13v to about 1.3.
When I pull it apart again il let you know what I see.
Old 30th May 2012, 04:51 AM   #7
I guess the transformer has a short. How hard is it to to fix??
Old 30th May 2012, 05:39 AM   #8
Perry Babin is offline Perry Babin  United States
It depends on where it's shorted.
Do you read 0 ohms between the RCA shields and the B+ terminal on the amp?
Old 30th May 2012, 12:41 PM   #9
No I do not. I had to move the transform a bit to get it back into protect.
Old 30th May 2012, 04:59 PM   #10
U can use epoxy to seal it or silicon.
autotek mm 2000.1dHide this!Advertise here!
autotek mm2000.1d timwebb Car Audio 6 23rd April 2012 02:34 AM
Power Acoustik BAMF 2000/1D Schematic? blazer40 Car Audio 5 28th January 2012 03:40 AM
autotek MM1000.1D xtremesound Class D 0 23rd February 2006 12:52 AM
