Powerbass ASA1500.1Dx
Old 6th May 2012, 12:00 AM   #1
brandes.cm is offline brandes.cm  United States
Default Powerbass ASA1500.1Dx
One bank of fets heats up quickly after power up. Initially the gate signal on the supply looks clean then after 15 seconds it gets noisy and the outputs start to heat up.
Thoughts?
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 6th May 2012, 08:56 AM   #2
timwebb is offline timwebb  United States
i still havent got mine to work right man.
Old 6th May 2012, 01:00 PM   #3
Does your driver card have a mixed mess of transistors? This one has 2n5401, 2n5501, A92,A56,A42's, not sure if that is right or not.
Old 6th May 2012, 01:16 PM   #4
yep i replaced them all except the op amp. and the resistors between would go one at a time.
Old 6th May 2012, 01:33 PM   #5
Interesting, might be a PIA since you need fets populated for it to oscillate.
sent from your blown amp....
Old 6th May 2012, 01:37 PM   #6
yea i know.they would blow every time installed new ones. i was going to replace the otpo couplers before i sat it to the side.
Old 7th May 2012, 03:18 AM   #7
Perry Babin is offline Perry Babin  United States
With no outputs installed, you can drive a strong 100Hz signal into the amp and it will show up on the output gates. That will show you if the drive circuit is working at a basic level (but won't be a good indicator of the high frequency performance). It may be possible to inject an 80kHz signal into the amp but I've never tried it.
Old 7th May 2012, 12:10 PM   #8
Is there a reference schematic close to this driver board? Should this oscillate at 40Khz?
Old 7th May 2012, 12:24 PM   #9
There is a schematic for this type of driver board on the DVD (Generic Class D - Type 2, item #14).
The frequency of oscillation will vary for self oscillating amps but it's generally between 60kHZ and 160kHz.
Old 7th May 2012, 12:35 PM   #10
Thanks, I will give that a look.
Powerbass ASA1500.1DxHide this!Advertise here!
Powerbass ASA1500.1Dx Dr Zeus Car Audio 11 26th November 2011 11:43 AM
Powerbass competition amp modification Dr Zeus Car Audio 14 17th June 2011 12:04 AM
PowerBass ASA 2000.10 Dr Zeus Car Audio 11 21st December 2010 12:38 AM
PowerBass ASA-600.4 audiobahnkid592 Car Audio 3 19th May 2010 09:12 PM
Powerbass thunderlaxton32 Car Audio 1 27th September 2007 01:26 PM
