SPL FX1-5500D Goes into protect
Old 30th April 2012, 12:28 AM   #1
bigpun4fubu is offline bigpun4fubu  United States
Default SPL FX1-5500D Goes into protect
It is in protect when powered up , power mosfets in circuit are shorted from drain to source.. I pulled one and it checks good out of circuit, assuming the rest would be ok but I check diodes D330 D331 D332 and D334 and they check open both ways in circuit , havent removed any to test yet , could these be the culprit?
Old 30th April 2012, 12:31 AM   #2
Old 30th April 2012, 05:11 AM   #3
Perry Babin is offline Perry Babin  United States
Do any of the power supply FETs read low resistance from leg 1-2?
HAve you checked the large diodes near the power terminals?
Old 30th April 2012, 08:40 AM   #4
checked reverse polarity diodes they are good ,ill check resistance and let you know on fets
Old 1st May 2012, 01:40 AM   #5
All power mosfets read 18+ Mega Ohms across legs 1-2
Old 1st May 2012, 05:08 AM   #6
nonprof is offline nonprof
I think it looks good. might try to do the same test to the output MOSFET.
Old 1st May 2012, 06:49 AM   #7
That would almost certainly mean that all of the power supply FETs are OK.
Old 1st May 2012, 11:43 PM   #8
the output fets on upper right of photo are shorted so surely this would be the problem
where can i locate the drivers? to check those?
Old 2nd May 2012, 01:01 AM   #9
When you stated that the 'power FETs' were reading shorted, I assumed (mistakenly) that you were referring to the power supply FETs.
The drivers for the audio output transistors are likely on the vertical board.
Old 2nd May 2012, 01:33 AM   #10
ok ive located the problem the 5 bad outputs,i removed them and it powers up with a green light
SPL FX1-5500D Goes into protectHide this!Advertise here!
Power Acoustic OVN1-5500D mike49504 Car Audio 14 29th February 2012 11:25 AM
Power Acoustik PS1-5500D m4ick Car Audio 20 22nd December 2011 02:28 AM
power acoustik ps1-5500d bdgf2004 Car Audio 7 14th September 2011 05:16 PM
Power Akustic LFA1-5500D Simbalage21 Car Audio 4 29th April 2010 10:39 PM
Kole KX1-5500D in protect mode. Shorted diode? barros57 Class D 2 13th February 2010 01:41 PM
Copyright ©1999-2017 diyAudio
