Kicker KX1200.1 - U508 and U509
Old 2nd May 2012, 01:34 AM   #11
Perry Babin is offline Perry Babin  United States
It doesn't appear that the IC is working properly. I don't think that there is any input condition that can make both outputs match. They should be at opposite supply voltages if the amp isn't working properly and something other than exactly 0v when the amp is working properly. It's also strange that the input pins are at 0v. I'd expect them to be something other than exactly 0v.
Old 2nd May 2012, 01:46 AM   #12
nonprof is offline nonprof
ok...il think of it.
how about the jumper connection? before I did the connection the amp alternately on/off then I followed the jumper, the amp is not anymore going to protect. what is the purpose of the jumper?
Old 2nd May 2012, 02:04 AM   #13
You shouldn't start a new post for an ongoing repair. Post a link to the point in the thread where the jumper is mentioned.
Old 3rd May 2012, 12:26 AM   #14
I found the the jumper function, it is for shorting the comparator output to GND then checking if there is DC offset after this comparator.
You're right outputs are complimentary, I will replace the LM316.
Thanks Perry!!!
Old 9th May 2012, 07:07 AM   #15
neighborhoodguy is offline neighborhoodguy
Hey nonprof, I'm having a similar problem - did the LM316 get hot when you turned the amp on?
Old 9th May 2012, 08:19 AM   #16
LM361, not LM316.
Old 10th May 2012, 12:11 AM   #17
didn't notice that heat...some IC get hot on normal operation. The way you should check it, get the functional diagram and trace the flow. LM361 is not quite complex.
Old 27th December 2013, 08:18 PM   #18
Formas is offline Formas  Jamaica
Default KX1200.1
Good evening Perry, is there any cross reference or other substitute that can be used for the LM361 on this amp (Kicker KX1200.1)?
Old 27th December 2013, 08:45 PM   #19
The only other IC I know that's compatible is the NE529. That's the one I was using before I found the exact part number being used.
If you have any other questions, please start a new thread or email me.
Old 14th September 2014, 12:40 AM   #20
Good evening perry, (I know you said start a new thread)....I have a problem with the input board for this amp, resistor R116 on audio input board can you tell me what value is that resistor?
Kicker KX1200.1 - U508 and U509Hide this!Advertise here!
kicker kx1200.1 getmoney2957 Class D 1 7th July 2012 11:24 PM
another kicker kx1200.1 gettinthechewin Car Audio 30 3rd March 2012 11:54 PM
kicker kx1200.1 timwebb Car Audio 8 24th January 2012 02:38 AM
Kicker kx1200.1 catfishermike Car Audio 3 18th April 2010 02:50 AM
Kicker KX1200.1 went up in smoke phil33875 Car Audio 10 25th March 2010 01:37 AM
