Orion HCCA 2100 fan-what one and where to buy? - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 29th April 2012, 02:14 AM   #1
Default Orion HCCA 2100 fan-what one and where to buy?
Hi
Anyone know the right fand for the 2100/2250? And where do I get them?
thanks john
thanks John
Old 29th April 2012, 02:39 AM   #2
Have you removed the fan? It should have a model number. Look up the datasheet to get the specs for it.
Old 29th April 2012, 10:36 AM   #3
It is the 8 screws and the fan is connected to the board-correct?The whole board/rail slides out?
Also,I have a major cleanup on the exterior of this 2100 between super dirt that has been baked on and corrosion,have you ever come across some super solvent that cleans without stripping the paint?
thanks John
Old 30th April 2012, 04:41 AM   #4
You can slide both heatsinks out without removing the screws holding the clamps down. I think there are 4 screws on the corners of each heatsink.
I've never had to clean an amp with that finish. Whatever you use, try it on the inside first to make sure that it doesn't damage the finish.
Old 30th April 2012, 06:28 AM   #5
I actually have 2
-One that needs cleaned and a new fan shroud put in
-another needs fan
I have removed the 8 heatsink screws and one broke damnit,so i drilled it enough to remove the heatsinks.I have started cleaning but the stuff is like bondo and you have to scrape it with a screwdriver(very carefull) to get to the red.
I dont know how i am going to get the rest of the screw out...drill it i suppose and tap/die(have not done since high school-LOL)
thanks John
Old 30th April 2012, 02:11 PM   #6
If you can find a household cleaner like 409/Fantastic that won't damage the finish, spray it and let it soak for about 15 minutes then use a pressure washer (car wash) to clean it. A plastic pot scrubber may help getting the stubborn material off.
Old 1st May 2012, 12:09 AM   #7
i will try that
thanks John
Orion HCCA-2100 and 2250-XRT/SX repair/refurbishing masters? mclsound Car Audio 3 12th March 2012 10:26 PM
orion 2100 HCCA amplifier trustyrusty10 Power Supplies 3 1st June 2010 01:31 AM
orion 2100 hcca mike49504 Car Audio 11 11th February 2008 02:14 PM
Q Orion HCCA 2100 competition amp Leif Car Audio 7 13th October 2006 06:10 AM
Need pictures of orion 2100 output?Please! shallowfu Car Audio 5 31st August 2006 07:37 PM
Copyright 1999-2017 diyAudio
