Directed 750D
Directed 750D
Old 27th April 2012, 12:51 AM   #1
mike49504 is offline mike49504  United States
Default Directed 750D
Amp is stuck in protection mode ... All outputs test fine..
Heres what i have on the 494
Pin 1:0
Pin 2:4.85
Pin 3:0.05
Pin 4:4.72
Pin 5:1.40
Pin 6:3.42
Pin 7:0
Pin 8:13.80
Pin 9:0
Pin 10:0
Pin 11:13.80
Pin 12:13.80
Pin 13:4.85
Pin 14:4.85
Pin 15:4.85
Pin 16:0
Any ideas where to check?
Old 27th April 2012, 01:03 AM   #2
Perry Babin is offline Perry Babin  United States
Pin 4 is high. If there is a PNP transistor that's connected to pins 14 and 4, pull it to see if the amp will power up. This will disable the protection circuit so clamp all transistors, small fuse or limiter....
Old 27th April 2012, 01:10 AM   #3
Removed the transistor amp powers up and idles fine also produces clean audio..
Guess i will replaced it and see if thats all it was..
Old 27th April 2012, 01:12 AM   #4
That's the last component in the protection circuit. Similar amplifiers have thermistors, comparators and other transistors driving that transistor so if that's not the problem, you'll have to follow the circuit back and see what's driving the base of that transistor.
Old 29th April 2012, 07:06 PM   #5
I replaced the transistor and amp was working great so i gave it back..
Not 2 hours later he brought it back and said something blew up in it..
I tested all outputs They all test fine I also checked the rca shield ground legs where they solder to the board they look fine..\
With only power ground and remote hooked up NO RCA'S if i hook a test speaker to it I get a Very loud noise from the spaeker like its fluttering back and fourth like crazy...
The is no DC across the speaker terminals..
Any ideas ?
Old 30th April 2012, 04:50 AM   #6
Are any of the potentiometers or switches broken?
Does operating them through their entire range make any difference?
Directed 750DHide this!Advertise here!
Directed 750D mike49504 Car Audio 4 18th April 2012 08:15 PM
Directed 1100 D mike49504 Car Audio 5 18th June 2011 06:40 PM
Directed 1500D mike49504 Car Audio 29 17th June 2011 05:28 AM
Directed 1100D spooney Car Audio 8 13th March 2011 12:17 AM
Directed 250D mbates14 Car Audio 2 9th February 2011 09:32 PM
