Need assistance for my PWM IC reading
Old 24th April 2012, 05:32 AM   #1
nonprof is offline nonprof
Default Need assistance for my PWM IC reading
Hi Perry/All,
Can you please check if i'll have a defective TL494 IC? Here is the reading
1. 0V
2. 4.8
3. 0
4. 4.5
5. 1.4 - found a sawtooth waveform here
6. 3.6
7. 0
8. 13
9. 0
10. 0
11. 13
12. 13
13. 4.4
14. 4.9
15. 4.9
16. 0
best regards,
Armand
Old 24th April 2012, 11:26 AM   #2
Perry Babin is offline Perry Babin  United States
The IC looks OK but something (external to the IC) is driving pin 4 high which is shutting down the drive pulses.
Old 27th April 2012, 01:56 AM   #3
thanks! ill check it.very much appreciated.
Old 27th April 2012, 02:04 AM   #4
By the way Perry, what should be the voltage into pin 4 in order to work?
Old 27th April 2012, 02:07 AM   #5
It typically has to be below the DC voltage on pin 6 for the IC to produce pulses. It has to be near ground to allow the power supply to go to full duty cycle.
Need assistance for my PWM IC readingHide this!Advertise here!
CROSSFIRE XP600D need PWM DLI4060B ic Hectorscaraudio Car Audio 13 29th November 2011 03:13 PM
search pcb with IC tl494 or other Ic to build a smps caraudio Ground Zero Car Audio 0 13th December 2010 05:58 PM
simple ic for 0-100% duty cycle PWM sss Power Supplies 6 2nd June 2010 02:34 PM
Rotel RCD971 reading problem - assistance/advice needed fixilator Digital Source 5 13th September 2008 11:32 AM
push-pull PWM IC chimi Power Supplies 19 4th September 2008 10:32 AM
Copyright ©1999-2017 diyAudio
