Memphis 16-PR1KD
Memphis 16-PR1KD
Old 25th April 2012, 07:34 AM   #11
Perry Babin is offline Perry Babin  United States
I think that should work. Also confirm that the Zener connected to the base of that transistor is within tolerance (6.2vZ).
Old 26th April 2012, 12:34 AM   #12
RiLoWa is offline RiLoWa  United States
RiLoWa's Avatar
I will check that diode.
I am not sure if the MJE344 is a possible substitute for the 2SC3200. Otherwise, I am not finding a good one. The 3200s check ok out of circuit, but the one at Q19 is heating the board below it.
Tools - 1. TPI Scope Plus 440 2. B&K 2125 20MHz Dual Trace 3. Sorensen DCR20-50B 4. B&K 4011 5MHz Function Generator 5. Weller WESD51 6. A big hammer
Old 26th April 2012, 10:46 PM   #13
RiLoWa's Avatar
I measure 5.93V accross D8. Not sure of the tolerance but that is within 10% of 6.2V.
Should be OK?
Old 26th April 2012, 11:51 PM   #14
I think it should be close enough. Did you replace the drivers yet?
Old 27th April 2012, 12:25 AM   #15
RiLoWa's Avatar
No sir, I have not. I will have to order those parts.
Should I order the BD139 and the KSA1220A along with them?
What about the the 2SC3200? They test OK out of circuit.
Old 27th April 2012, 01:10 AM   #16
I'd suggest ordering the following just to have them on-hand.
BD139 and 140
KSA1220a and KSC2690A
MPSW42 and MPSW92
Also order the clip-on heatsinks for the TO-92 transistors.
Old 12th May 2012, 11:22 PM   #17
RiLoWa's Avatar
Replacing the eight drivers with w42s and w56s did not change the symptom. The original set checked out ok out of the circuit. I forgot to get the parts you posted just above, so I will have to get those if they become vital to continued testing.
Old 14th May 2012, 12:50 AM   #18
Did you replace all of the other transistors that showed signs of overheating (the ones with bad solder joints)?
Old 15th May 2012, 03:33 AM   #19
RiLoWa's Avatar
After replacing all of the transistors except for a pair of 2N5401s, the amp appears to be working correctly. I think it may have just been a broken leg on Q21 (A1275) that was the problem which was the last transistor I replaced. Hard to know for sure, I will have to do more testing on it tomorrow.
Old 15th May 2012, 07:58 AM   #20
If you want this amp to be reliable, long term, install heatsinks on the transistors that get too hot to touch within 1 minute. This will help reduce their operating temperature which will reduce the thermal stress on the circuit board and will help prevent premature failure of the transistors.
Memphis 16-PR1KDHide this!Advertise here!
Memphis 16-PR1KD amp repair help (pix) raverx3m Car Audio 15 24th April 2012 08:07 AM
Memphis 16-MCA3004 Dr Zeus Car Audio 19 24th February 2012 09:54 PM
Memphis 16-PR1KD timwebb Car Audio 13 6th July 2010 10:13 PM
problem with my amp memphis 16-pr1kd pollo1008 Class D 0 29th December 2009 10:20 PM
memphis 16-pr1kd chev55_steve Car Audio 0 2nd January 2009 10:46 AM
