#11 |
Add BD139 and BD140 to the following list.
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ Generic (applies to MANY amps): ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ * For amps that use SMD resistors, keep a good selection of sub 1000 ohm 0805 resistors and sub 500 ohm 1206 resistors. * For most all of the amps below, the IRF3205 is a good sub for PS FETs rated greater than 50 amps. The IRFZ44 is a good sub for PS FETs rated for 50 amps or less. * For amps greater than 10 years old, you may want to replace all of the electrolytic capacitors. These will vary too greatly to include suggestions for replacements here. * PS driver ICs TL594 and SG3525 will cover most amps. SG3524 and SG3526 are also common but are rarely needed. * For generic amplifiers, the power supply gate resistors often open or change value. Stock both 1/4 watt and 1/8w of 10, 27, 33, 47, 68 and 100 ohm resistors. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ Rockford (older punch BBQ and Batman style amps): ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ IRF540 IRF9540 IRF640 IRF9640 (larger amps) 0.1 ohm 3 watt dale 1% resistors (LVR03R1000FB12) MMBTA06 MMBTA56 20 ohm SMD 0805 10 ohm SMD 0805 100 ohm SMD 0805 51 ohm SMD 0805 39 ohm SMD 0805 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ Rockford (newer Px002, etc.): ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ FQA36P15 FQA28N15 0.1 ohm 3 watt dale 1% resistors (LVR03R1000FB12 - very good for any amp needed a 2-3 watt emitter/source resistor) MMBTA06 MMBTA56 20 ohm SMD 0805 10 ohm SMD 0805 22.1 ohm SMD 0805 100 ohm SMD 0805 51 ohm SMD 0805 39 ohm SMD 0805 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ Rockford (older BD): ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ IRF3415 IRF6215 15 ohm 1/4w axial resistors 24.1 ohm 1/4w axial resistors 10 ohm SMD 0805 MPSA56 MPSA06 TL072CD LM6361 LM6171BIN LM6172IM MIC4420CT HCPL2211 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ Kicker (older ZR series): ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ TIP35C TIP36C RFG70N06 TL071CD TL072CD ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ MTX: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ IRF3415 (for smaller class D outputs like in the 6500d) MPSA56 PZTA06 PZTA56 10 ohm SMD 0805 47.5 ohm SMD 0805 NE5532P NE5532D ES2D diodes ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ Orion (older): ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ 2N6488 2N6491 NDP7060 10 ohm 1/4w axial resistors MPSA56 MPSA06 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ JL Audio ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ IRF540 IRFZ44N 47.0 ohm 1206 SMD resistor 75.0 ohm 1206 SMD resistor 100 ohm 1206 SMD resistor 200 ohm 1206 SMD resistor ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ SoundStream (older) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~ TIP102 TIP107 2SA1562 2N2222 0.27 ohm 2w axial resistors 3.3 ohm 1/4w axial resistors 0.1 ohm 3 watt dale 1% resistors (LVR03R1000FB12) 34 ohm 1/4w axial resistors
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#12 |
Thank you for all your help!
#13 |
On r60a I reads 4.7v on r60 I'm reading 1.4v is that normal? (Sides closest to drivers)
#14 |
Probably not. Are the drivers identical?
Have you removed them to confirm that all are in good condition?
#15 |
I used the bd139 and 140, and I have not removed them yet. I did remove the side of the resistors closestto the drivers and the voltages went up.
I've been staring at this too long il check them tomorrow. Thanks Perry |
#16 |
Those feed the drivers. I'd suspect a defective driver, a driver that's installed backwards or one that's in the wrong location.
#17 |
Could you verify q7 q7a q8 q8a? Maybe I wrote them down wrong.
#18 |
The center legs of the PNP drivers (BD140) will be directly connected (0 ohms) to the amp's ground terminal.
#19 |
I had the order correct i think i might have installed them backwards.
#20 |
The two resistors connect to the bases (pin 3) of the drivers.
| Hifonics amp | mike49504 | Car Audio | 10 | 5th January 2011 05:01 PM |
| Hifonics | dtisme | Car Audio | 3 | 7th August 2010 12:49 AM |
| Hifonics Brutus | lee1976 | Car Audio | 3 | 20th July 2010 11:19 AM |
| Hifonics Eros | Perry Babin | Car Audio | 8 | 28th December 2009 06:08 AM |
| Hifonics Cupid | Lasse- | Car Audio | 3 | 5th February 2004 10:28 PM |
