Go Back   Home > Forums > General Interest > Car Audio
Old 22nd April 2012, 02:02 AM   #1
Default Kicker SX900.4
Channel 4 is out, the drive signal looks fine at Q431 and Q441. When checking the signal at Q442 and Q432 the signal loses the top half of the signal on one and the lower half on the other one.
Looking at a schematic for the IX402 seems close, but doesn't have the redundant drivers for each output device.
help is appreciated.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 22nd April 2012, 02:10 AM   #2
Are the circuit board designations the same as the IX?
If not, you would need to list the designations for the corresponding parts.
Were the outputs in the board when you checked the drive signal?
Old 22nd April 2012, 02:30 AM   #3
Q431 and Q441 are Q150 and Q151 on the IX schematic
Q442,Q432 are Q160 and Q161 on the IX schematic
No outputs were populated, I had them in and it seem to produce a clean sine wave and then the outputs failed after a few minutes.
Old 22nd April 2012, 02:56 AM   #4
Placed 2 outputs and the signal looks fine. Maybe the first time I didn't have the clamps tight and the fets got hot and failed.
Old 22nd April 2012, 09:09 AM   #5
You can't check the drive signals in class A/AB/B amps that use negative feedback (most all commercially available amps) without the outputs in the circuit.
Kicker KX2500.1 brandes.cm Car Audio 10 5th February 2012 11:36 PM
Kicker DX350 Dr Zeus Car Audio 9 17th January 2011 11:13 PM
kicker kx450.2 timwebb Car Audio 21 1st July 2010 03:52 AM
Kicker SX650.1 help shagone Car Audio 12 19th March 2008 07:35 AM
Kicker Amps skooter Car Audio 3 8th November 2007 03:53 AM
Copyright ©1999-2013 diyAudio
