ATC Fuse Block - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 19th April 2012, 02:29 PM   #1
Default ATC Fuse Block
Hello,
I've got an old Orion Xtreme 800 for repair. Not sure what's happened to it just yet as the ATC fuse holder has melted. Does anyone know where I can get one from?
Nick
Old 19th April 2012, 03:08 PM   #2
Well I am not sure if this is the correct part but it appears you can stack these to build 2 or 3 or more. I am a noob at this as well
Littelfuse - 04450715H
04450715H Littelfuse Fuseholders, Clips, & Hardware
or
Digi-Key - F1908-ND (Manufacturer - 04450715H)
Datasheet
http://datasheet.octopart.com/044507...heet-13973.pdf
Old 19th April 2012, 04:02 PM   #3
Yeah this is the sort of thing I'm after but the ones I have in the amp have a 90 degree connection so it can be mounted at right angles to the PCB. I guess I could always screw them to the bottom case and run cables to the PCB.
Old 19th April 2012, 04:30 PM   #4
ebay:
370442813594
Similar but would need slight modification.
Old 19th April 2012, 04:46 PM   #5
Thanks Perry.
ATC 2-way inrank Multi-Way 6 31st December 2010 09:11 AM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Why main fuse and not rail fuse? digital desire Solid State 10 3rd December 2006 08:07 PM
amp rating for fuse and fuse holder? riotubes Parts 5 27th August 2006 03:10 AM
New Belgian on the block SpaBlauw Introductions 6 30th August 2003 09:10 PM
Copyright 1999-2017 diyAudio
