I have a gm7200m im working on. i dont have power anywhere but the fuses. i checked d665 and no voltage present at all on both leads . The unit is dead. Could someone point me in the right direction. I bought Perrys dvd but havent looked at it very much due to time.
#2 |
If you don't have voltage on the FETs, I'd suspect blown fuses or an open trace.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#3 |
IC 651 the pioneer 2027A 16 pin ic chip on the power supply
1-13.06vdc 9-16 were 0 exept 15 was .137vdc 2-0 3-13.63vdc 4-0 5-o 6-0 7-0 8-0 13.75vdc on one leg of C677 nothing on either leg of D665 T901 0 on all legs the thermister on it 0 on both legs 0vdc on L601 r650 had 13.75 on one leg and 11.56on the other and nothing on the power supply transistors |
#4 |
i am posting a picture of the amp
#5 |
If you don't have voltage on either leg of L601, there is a break in the connection between the fuses and L601.
#6 |
i cant believe i didnt see it before. L601 had a bad solder joint. I resoldered it and tested it. Its fixed. Thanks for the help. It was a great learning experience.
| Dead Dead Laser Pickups - why not replacing the Diode only? | Salar | Digital Source | 17 | 12th November 2012 11:10 AM |
| Pioneer Dex 77 radio wanted dead or alive | looneytuner | Swap Meet | 1 | 16th May 2010 06:46 AM |
| Pioneer won't switch on (like dead) | AudioAddicted | Car Audio | 21 | 14th February 2007 12:56 PM |
| Dead Pioneer Amp | Heavymetal_riff | Car Audio | 7 | 19th September 2005 10:02 AM |
