Go Back   Home > Forums > General Interest > Car Audio
Old 19th November 2003, 03:15 PM   #31
subwo1 is offline subwo1  United States
subwo1's Avatar
Hi davesaudio, here is a link to a circuit which I came up with in the past. The values of R1,R2,R3, and R4 should be adjusted for optimal performance.
http://f6.grp.yahoofs.com/v1/gJO7P2I...ghpowerout.gif
I can't think of any universal high side drivers off of the top of my head. But some lower voltage ones are out there.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 19th November 2003, 08:38 PM   #32
linky no worky?
should I rephrase " high side driver circuit using discrete components to drive the gate of the switching device beyond the rails?"
well something like that anyways...
intentionally blank
Old 19th November 2003, 10:36 PM   #33
subwo1's Avatar
Originally posted by davesaudio
linky no worky?
Sorry, try copying and then pasting the link into the browser window.
The circuit is a such as you seek, and it can charge and discharge high capacitance gates, or I should say, it is designed that way. I have not actually built and tested it.
USMPS
Old 19th November 2003, 10:44 PM   #34
subwo1's Avatar
davesaudio, there is a lower power high-side driver in the circuit in this class D amp which I actually tested as a real circuit.
http://f5.grp.yahoofs.com/v1/8PW7P-o...0class%20D.gif
USMPS
Old 19th November 2003, 10:47 PM   #35
tried 2 different browsers-no luck
intentionally blank
Old 20th November 2003, 12:22 AM   #36
subwo1's Avatar
Default 1st diagram
Ok, I went and got them, Here is the proposed high power version. Substitute V1 with a bootstrap diode and capacitor in the normal way.
USMPS
Old 20th November 2003, 12:29 AM   #37
subwo1's Avatar
Here is the other one.
USMPS
Devices we may be using in a few years for higher switching speed Class D bwaslo Class D 3 3rd March 2009 01:04 PM
power output higher than power supply...How? loonatron Analogue Source 9 24th March 2005 07:04 PM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 04:28 PM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 04:01 AM
Page generated in 0.09678 seconds (78.74% PHP - 21.26% MySQL) with 11 queries
