Im trying to repair this earthquake amp model 200dhc. few of the power supply transistors are defective so I'm replacing all of them .I do have the originals in stock but while checking for gate singal I'm getting 13v exactly as my power supply .Fets are being driven by a 8 pin Ic and the model number has been sanded off ,I'm guessing from the factory .I don't have that much experience but i believe the voltage is too high .If anyone have idea about this amp and the Ic model please let me know
thank you |
#2 |
I have repaired a similar amp (PH-D3).
If it uses 3525, check that both outputs (pins 11 and 14) are getting to the 8-pin chip. If thats the case, its probably a TC4424. |
| Earthquake 200dhc with hum in output | spooney | Car Audio | 23 | 27th November 2010 08:15 PM |
| Power Supply Repair Needed | childsid | Power Supplies | 0 | 10th September 2008 07:11 PM |
| Power Supply Problem/Repair | ak_47_boy | Power Supplies | 3 | 7th July 2008 10:36 PM |
| HV power supply repair | smoking-amp | Tubes / Valves | 1 | 17th February 2005 02:42 AM |
| Audio power supply repair | tennisballg | Car Audio | 11 | 30th April 2004 12:12 AM |
