Go Back   Home > Forums > General Interest > Car Audio
Old 14th April 2012, 08:55 PM   #1
ivkata is offline ivkata  United States
Default soundstream reference 414 driver card rebuild or possible replacement
thank you for taking the time to look at mu listing
I have Soundstream reference 414s for repair here as one of the channels was sending rail voltage on the speaker terminals.Ive removed all the outputs as 2 are defective as well as all gate resistors as 2 are dead as well.The issue I'm having is with the driver board as it appears that one of the large transistors got hot and 1 resistor connected to it looks brownish so I'm thinking about repairing or replacing this one.Please advice if those are available somewhere or maybe u have spares and wanna hook me up
thankxx
Old 14th April 2012, 11:24 PM   #2
They made two types of cards for this era of SoundStream amp. One with MPSa-18's as the input pair and one with a dual transistor in a single package 2SC3067 as I recall. Which one do you have ? Perhaps a picture if possible ?
Old 14th April 2012, 11:45 PM   #3
posting photo now i thought it might be easier to repair/replace this with the board out
thank you
http://www.freeimagehosting.net/48bbo
Old 15th April 2012, 01:11 AM   #4
Ah, You have the 2SC3381 input transistor. I have tech info on this. PM me if you like.
Old 15th April 2012, 02:59 PM   #5
azvrt is offline azvrt  Netherlands
I once had 30 volts DC on the speaker terminals of a Ref 300.
A short while later it did not function at all anymore.
Replacing the rectifiers permanently solved it.
Regardless, I would replace the rectifiers on your amp, while you're at it.
Also, check the quality of the solder joints of your driver boards, very important.
Looking at the schematics, it makes use of FEP16DT and FEN16DT rectifiers.
Jaime sells them, as well as the driver boards. Good luck !
Old 15th April 2012, 05:27 PM   #6
thanks for the advice .With this amp i don't see issues with the rectifiers as the other 3 channels output clean and loud audio.I will reflow the driver cards prior reassembling the amp back .Ive looked for Jaime on ebay but it appears he's no longer selling there .due to ebay crooked policies allot of good parts guys are no longer offering those hard to find parts .The main problem I'm having is supplying the 3381 that is no longer in stock on the main parts suppliers .I was able to find it on Futurlec however i have never purchased parts there so if someone had in the past ,please advice
Old 15th April 2012, 07:43 PM   #7
If 3 out of 4 channels are functioning properly then the rectifiers are fine.
I would DEFINITELY apply some fresh solder to the solder joints of the driver PCB's.
Then, without assembling the amp, power it on and check whether the bad channel functions properly. Do not have the amp play for more than a minute or it will overheat ! Try and perform your tests in no more than half a minute at a time.
If it functions properly, you can assemble it. If it doesn't, than it has other issues than the solder joints.
But I have seen it time and again, bad solder joints causing problems on these amps.
Before replacing parts, it's a thing to do.
Try contacting Jaime at jandrelectronix@aol.com for parts.
He's hard to reach though.
soundstream reference feb board replacement russdeanlee Car Audio 8 16th March 2012 11:46 AM
Soundstream Reference 405 mike49504 Car Audio 5 28th June 2011 12:09 AM
Soundstream Reference 405 mike49504 Car Audio 43 24th January 2011 05:29 AM
soundstream 414 ref repair dhamia Parts 0 14th July 2010 11:02 PM
altec 414/comp driver crossover stuck.wilson Multi-Way 4 5th November 2006 08:36 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
