RF punch 40i DSM won't power on - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 13th April 2012, 05:45 PM   #1
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Default RF punch 40i DSM won't power on
Hi, I got this a punch 40i dsm amp I'm having trouble with it. I replaced the power supply devices with irf3205 mosfets. Before replacing them I checked all the BUZ11's output all of them seem to measure normal on diode check. So I went ahead and put in new power supply fets and as soon as I plug in power it puts my power supply into protect. On the bottom of the board near B+ & GND theres a open trace that connects to the B+ terminal. I soldered it and that's when it kept making my power supply go into protect. I'm not sure what's the problem. I checked D4 & D5 and C12. They measure shorted when in circuit but when I unsolder that trace on the bottom those components measure fine. Any help would be great. Thanks
Feel the PUNCH
Old 14th April 2012, 05:04 AM   #2
seankane's Avatar
Did you change the power supply gate resistors to 47 ohm?
Did you change the drive transistors on the power supply driver board?
When a power supply fails it is best to change all related components, as they could be damaged or leaky.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 14th April 2012, 06:10 AM   #3
Never mind I got it to work now. It was a shorted diode near C12. I'm guessing someone reversed the polarity when hooking it up and shorted a diode. None of the BUZ11 out puts where shorted so that saved me some more work...wheww
Also how does this output stage work when it has all BUZ11 N channel mosfets. I thought this would use the typical IRF540 & IRF9540.
Feel the PUNCH
Punch 40 DSM seankane Car Audio 36 21st November 2011 04:11 PM
Stumped on RF Punch 100 DSM amp - help m109ner Car Audio 77 19th June 2011 01:41 AM
PUNCH 4080 DSM bdgf2004 Car Audio 4 21st March 2011 07:45 AM
punch 40 dsm bdgf2004 Car Audio 10 11th January 2011 12:03 AM
punch 40i power up but no sound bass-mechanic Car Audio 3 26th April 2009 06:11 PM
Copyright 1999-2017 diyAudio
