Lanzar OPTIDRIVE 2150
Old 13th April 2012, 03:30 AM   #1
mike49504 is offline mike49504  United States
Default Lanzar OPTIDRIVE 2150
Anyone have a pic of the board around the SG3525 ??
Or possibly know the value of R72 ?
Old 13th April 2012, 09:48 PM   #2
The orginal power supply fets are P50N06'S with10 ohm gate resistors..
If i switch the fets over to IRF3205's would i need to change the value of the gate resistors and if so what value ??
The drivers for the power supply are 2N4401 and 2N4403
Old 13th April 2012, 11:36 PM   #3
ultra is offline ultra
ultra's Avatar
Can you be a bit more specific about the location of R72?
I got the schematic of a similar amp (125Wx2).
If you change to IRF3205, 47R is a good gate value.
Old 14th April 2012, 03:19 AM   #4
I was going thru my stuff and found some STP60N06'S
Would thoose work better then the 3205's as replacements for the
STP50N06'S ??
If so would i need to change the value of the gate resistors from 10 ohms ??
STP60N06-14 pdf, STP60N06-14 description, STP60N06-14 datasheets, STP60N06-14 view ::: ALLDATASHEET :::
STP50N06 pdf, STP50N06 description, STP50N06 datasheets, STP50N06 view ::: ALLDATASHEET :::
Old 15th April 2012, 01:36 AM   #5
Perry Babin is offline Perry Babin  United States
The 10 ohm gate resistors will work with any of the FETs you listed.
If you're looking for the value of a burned resistor near the PS driver IC, it's likely one of the two resistors that are connected to the output pins of the IC. It's a low value resistor (100 ohms or less). Find the one connected to the other output pin of the IC to get the value.
Lanzar OPTIDRIVE 2150Hide this!Advertise here!
Lanzar Optidrive 4000D problem Custom Chris Car Audio 55 10th July 2011 08:14 PM
Need Help With Lanzar OptiDrive KansasKowboy Car Audio 2 1st April 2010 02:41 PM
lanzar optidrive 1400d Hi Speed Car Audio 1 26th March 2010 03:38 PM
lanzar optidrive 2500 abortion amc32 Car Audio 4 20th April 2008 08:41 PM
Lanzar Optidrive 6200 LORNECALIFORNIA Car Audio 2 18th January 2008 02:03 AM
