clarion apx4240
clarion apx4240
Old 12th April 2012, 03:40 AM   #1
DREW028 is offline DREW028  United States
Send a message via AIM to DREW028
Default clarion apx4240
Anyone have the service manual?
Front left channel has low ouput. I think its a op amp but I can't get board out yet to trace the signal cause 2 screws are stripped
Old 12th April 2012, 06:35 AM   #2
Perry Babin is offline Perry Babin  United States
Can you drill the heads of the screws to remove them to allow the amp to be disassembled?
Although you can't rule out an op-amp. It's extremely unusual for an op-amp to have low gain. It's generally a problem with a potentiometer, a resistor or a capacitor.
Old 14th April 2012, 02:04 AM   #3
Ha, simple fix it was a cap right at the rca inputs. Old one is a 50v 10uf. Would it make a difference if I replaced the 1 with a 22uf 50v or should I change all 4?
Old 15th April 2012, 01:29 AM   #4
The 22uF would probably work but you should use the same value. It's a bad habit to use parts that are not the same as the originals.
clarion apx4240Hide this!Advertise here!
clarion dxp11551 timwebb Car Audio 2 22nd May 2011 05:36 PM
Clarion DPX11500 m4ick Car Audio 1 12th April 2011 03:37 PM
Need help!!!I’m retarded… Clarion wiring….. fredrow Car Audio 3 14th March 2009 09:52 AM
Need Help with Clarion Deck...PLEASE.... fredrow Car Audio 14 9th March 2009 11:36 PM
Clarion nbcd Car Audio 1 8th August 2005 05:27 PM
