Go Back   Home > Forums > General Interest > Car Audio
Old 12th April 2012, 01:40 AM   #21
no i don't have a scope yet.Am looking for one
Old 12th April 2012, 02:02 AM   #22
picc
Old 12th April 2012, 06:30 AM   #23
The power supply driver IC is a KA7500. It's essentially the same as a TL494/594.
Without a scope, it's going to be difficult to trace the problem. You stated that the driver transistors were OK. If the gate resistors are OK, you really need to be able to look at the signal.
What is the value of the gate resistors?
What are the power supply FETs that you installed?
Old 12th April 2012, 11:16 PM   #24
gate resistor 47 ohms
Powere supply FETs irfz44n replace with the same
owener just told me he think someone try to power this amp up with 220v AC
Nothing in this amp looked badly burnt. All i found bad was two shorted outputs and leaky PS FETs.Also one rectifier had an open circuit from the middle leg to the body.i change both. Both rectifiers are out of circuit
Old 13th April 2012, 01:01 AM   #25
There shouldn't be a problem with those FETs and resistors.
With the rectifiers out of the circuit, are you reading something near 5v DC on the gates of the power supply FETs?
Old 13th April 2012, 01:34 AM   #26
Three of them read 3.03v and the other three read 3.08v
Old 13th April 2012, 02:48 AM   #27
What's the DC voltage on pins 9 and 10 of IC1 on the power supply driver board?
Old 13th April 2012, 02:57 AM   #28
#ka7500 IC
pin 9 3.05v
pin10 10.03v
Old 13th April 2012, 03:00 AM   #29
These should be very nearly identical, especially considering that the voltage on the gates of the FETs is nearly identical.
Are you sure that you have the pins right and there were no mistakes measuring the voltage?
If there was no mistake, post the voltage on all pins of IC1.
Old 13th April 2012, 03:37 AM   #30
sorry i check the wrong pins
pin 9 3.37v
pin 10 3.40v
IC is had to reach
I will post the voltage on all pin after i take the card out of the board and used wire to connect it back to the boad
Atomic AT-5000.1D mike49504 Car Audio 19 24th August 2011 01:58 AM
Magnepan Tympani 1D ROCKMANDRAKE Planars & Exotics 4 7th May 2009 06:54 PM
Crunch 1000.1D amp Hi Speed Car Audio 1 3rd September 2007 05:33 PM
autotek MM1000.1D xtremesound Class D 0 22nd February 2006 11:52 PM
Edirol UA-1D - opinions george a Digital Source 0 29th October 2005 11:40 PM
Copyright ©1999-2013 diyAudio
