Diablo 2500.1 output driver card
Old 29th March 2012, 04:29 AM   #1
brandes.cm is offline brandes.cm  United States
Default Diablo 2500.1 output driver card
Has anyone seen this module before? Attached are a few pics with some text added as to what I see on a few pins.
One doesn't have the triangle generated while the other does, but the signal at the gate resistors does not exist.
Old 29th March 2012, 04:31 PM   #2
Perry Babin is offline Perry Babin  United States
I don't have anything on this amp.
There should be a campaign against manufacturers that will not provide full schematic diagrams or good technical support. Having a list of good/bad manufacturers would allow buyers to confirm that they will easily be able to get their amps repaired. Sending it back to the manufacturer isn't always a good option. I've been told that people have had to wait more than 6 months to get their amps back when sent to the manufacturer.
Old 29th March 2012, 05:53 PM   #3
Talking with the owner who commissioned the build; he can't get any info from the manufacturer either.
They file the names off the parts and it makes it impossible to fix.
This may go back to the kid still damaged.:thumbdown:
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 29th March 2012, 06:31 PM   #4
I think the ICs are a LM319 and a TL072. I found some notes I made when working on a memphis with a similar board.
Old 13th May 2012, 08:51 PM   #5
This driver card is used on the Memphis PR 500.1 or equivalent series amps. Does memphis offer up schematics, anyone have one?
Old 13th May 2012, 09:40 PM   #6
mike49504 is offline mike49504  United States
I have a driverboard sitting here thats the same one..
Old 14th May 2012, 12:44 AM   #7
I can input a 40hz signal and see it at the gates, one side is riding on +rail and the other is at -rail. This is without any outputs populated. Loading the gate with a cap eliminates any squarewave that was present. Best I can tell the driver cards are operating, partially!
thoughts?
Diablo 2500.1 output driver cardHide this!Advertise here!
Blown Diablo Prototype Repair DIY help please Drsnazzy Car Audio 8 15th December 2011 08:05 PM
Need output driver card info for Hifonics Cyclops Deadly Sones Car Audio 2 19th October 2011 10:29 PM
memphis 1500 driver card timwebb Car Audio 4 22nd April 2011 04:17 AM
memphis mojo driver card timwebb Car Audio 13 1st May 2010 10:46 PM
Help w/ Diablo 5000 amp Tom7227 Class D 0 27th December 2009 08:15 PM
