Rockford Power 550X 4 Channel
Old 26th March 2012, 08:37 PM   #1
seankane is offline seankane  United States
seankane's Avatar
Default Rockford Power 550X 4 Channel
Hello all. I have a Rockford Power 550X I am working on with a small issue.
The board number is PC-3094-E.
When it came in it had no audio. I replaced the RCA jacks and D2 and D3.
The amp powers up fine and idles fine, no current draw or anything unusual.
All channels bias fine and produce clean audio.
However....The right rear negative bridging terminal has -1.836 vdc on it.
The only time I notice a problem is running it bridged. At low or no volume it is very staticy. Once the volume is increased it sounds totally fine.
I am kinda stumped here as in where to look for a problem.
Anybody have any ideas?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 26th March 2012, 10:02 PM   #2
Perry Babin is offline Perry Babin  United States
Do you have the same voltage on the two bases of the differential amplifier transistors?
Old 26th March 2012, 10:41 PM   #3
seankane's Avatar
As in Qx105 and Qx106?
Old 27th March 2012, 12:02 AM   #4
Qx01 and Qx02.
Old 29th March 2012, 02:57 AM   #5
seankane's Avatar
All the bases read the same: 0.047 vdc except Q301 and Q302.
Q301 reads -1.285 vdc
Q302 when tested showed about 0.533 vdc but made the amp draw 20 amps on my supply and screech.
Old 1st April 2012, 12:22 AM   #6
seankane's Avatar
Hey Perry did you get a chance to read my last post?
Old 2nd April 2012, 08:41 PM   #7
What is the DC voltage measured directly across the following resistors. I would ask for them in smaller groups but I haven't had much time to visit the forum.
R317-R323 and R326.
Old 3rd April 2012, 04:15 AM   #8
seankane's Avatar
R317: 0.039 vdc
R318: 0.040 vdc
R319: 4.82 vdc
R320: -0.361 vdc
R321: 0.378 vdc
R322: -1.152 vdc
R323: -0.534 vdc
R326: 0.525 vdc
Old 3rd April 2012, 05:34 PM   #9
I don't see anything there that's unexpected.
With the black probe on the negative speaker terminal, what's the DC voltage on the 4 terminals of C312 and C314?
Old 23rd May 2012, 05:46 AM   #10
seankane's Avatar
Hello Perry its been awhile since I posted on this not sure if you remember where we were at.
Black probe on negative speaker terminal and red probe on
C312: 0.946 vdc
C312: 2.574 vdc
C314: 1.248 vdc
C314: 3.145 vdc
Let me know what you think.
Rockford Power 550X 4 ChannelHide this!Advertise here!
Rockford fosgate 550x mike49504 Car Audio 15 10th June 2011 05:11 AM
rockford 501s one bad channel stoke Car Audio 18 23rd February 2011 04:43 PM
Rockford fosgate 550x mike49504 Car Audio 1 11th February 2011 12:30 PM
Rockford Power 550x bias issue brandes.cm Car Audio 5 24th November 2009 01:13 PM
rockford fosgate 550x mike49504 Car Audio 21 6th December 2008 10:26 PM
