Rockford Power 550X 4 Channel - Page 6 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 5th February 2013, 08:08 AM   #51
It's not straight DC. The channel is oscillating. It appears as DC because the oscillation waveform isn't symmetrical (well, that's a guess).
Clamp the outputs and set the bias so that it goes back to a straight line (minimum bias that achieves that). What is the DC voltage across each of the 0.1 ohm source resistors?
Old 5th February 2013, 08:23 AM   #52
seankane's Avatar
I think you are correct, I will do that now. I replaced all the outputs and drivers on that side of the amp.
Its acting like an un biased Power 650. If you view the output throught the scope at an idle, you have to increase the bias to get a straight line and get rid of the noise.
The lower the bias the bigger the haze or noise.
I will check what you asked right now.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 5th February 2013, 08:36 AM   #53
seankane's Avatar
Please read post #52 first.
I set the bias on the 2 channels just until the line went straight. Its drawing about 2 amps current.
R449 0.007 vdc
R436 0.007 vdc
R349 0.033 vdc
R336 0.033 vdc
These voltages were measured across the source resistors.
All channels produce clean audio, but 2 only do as long as the bias is set. I have not tested on speakers yet, but as far as a waveform on the scope 2 have bad ascillation if the bias is not set.
Old 5th February 2013, 01:44 PM   #54
I don't know which channel you set the bias on first so try this. Set the bias fully CCW on those channels and bias the 300 series channel first, then the 400 series channel.
Note the voltage across the 0.1 ohm resistors.
Now go back to fully CCW and bias the 400 then the 300 series channel and note the resistor voltage.
I'm trying to determine if one channel is causing the other channel to oscillate. If only one channel is actually defective, maybe stopping it from oscillating will allow the other channel to be set at a normal bias.
Rockford fosgate 550x mike49504 Car Audio 15 10th June 2011 05:11 AM
rockford 501s one bad channel stoke Car Audio 18 23rd February 2011 04:43 PM
Rockford fosgate 550x mike49504 Car Audio 1 11th February 2011 12:30 PM
Rockford Power 550x bias issue brandes.cm Car Audio 5 24th November 2009 01:13 PM
rockford fosgate 550x mike49504 Car Audio 21 6th December 2008 10:26 PM
Copyright 1999-2017 diyAudio
