Rockford Power 550X 4 Channel
Old 15th September 2012, 04:49 AM   #41
seankane is offline seankane  United States
seankane's Avatar
The board number is PC-3094-E
It is alot different from the 600a4. You have the same schematic I do. I believe its the same as the 551X 4 channel the silver with blue emblem. This is the older 2002 model grey heat sink with the red light in the badge.
I posted a pic of the board and the section giving me issues.
I dont believe I have the right schematic kinda the same set up as a 400a4 just a little different.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 15th September 2012, 10:41 AM   #42
Perry Babin is offline Perry Babin  United States
Are the circuits for the output stage identical in the schematic we're using and your amp?
Did you measure the gate-source voltage for Q310/311 when they were in the circuit?
Old 20th September 2012, 05:11 AM   #43
seankane's Avatar
I did not measure the gate to source voltage before removing Q310/Q311 should I pu them in and check?
I am not 100% if the circuits are the same I have a few 600a4's laying around maybe I will pop one open and look. Seems it would be easier to tell that way.
Old 23rd September 2012, 09:56 AM   #44
seankane's Avatar
Hmmmmm
Old 23rd September 2012, 12:32 PM   #45
brandes.cm is offline brandes.cm  United States
The 550x schematic I have is labeled h400a4.
https://sites.google.com/site/brande...edirects=0&d=1
Not sure its much help.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 23rd September 2012, 08:01 PM   #46
seankane's Avatar
Should I put Q310 and Q311 back in a measure voltages Perry?
Old 23rd September 2012, 08:04 PM   #47
#43:
Yes.
Old 5th February 2013, 06:28 AM   #48
seankane's Avatar
Back to this amp.
They measure about the same as the rest of the FETS.
Q311 IRF9540 G-S: +2.967 vdc
Q310 IRF540 G-S: -2.438 vdc
Still have the -2.702 vdc on the bridging terminal.........but.......
IF I increase the bias for that channel just until the amp starts to draw current and leave it all the voltage on the bridging terminal goes away but the 2 fets in that channel start to get warm.
Wierd thing is if I am touching the bridging terminal with my meters probe and adjusting the bias at the same time, when I insert the small screw driver into the pot to adjust, touching the screw driver to the metal in the pot makes it draw current, like 8 amps. If I remove the probe from the bridging terminal it does not draw any current when using the screw driver.
Old 5th February 2013, 06:39 AM   #49
Do you see straight line DC on the output or do you see something else?
Old 5th February 2013, 07:23 AM   #50
seankane's Avatar
If you are referring to what it looks like on the scope, its not straight line, its a big blur about 3" wide on my scope screen.
If I remove Q305 and Q306 the DC on the bridging terminal goes away.
Rockford Power 550X 4 ChannelHide this!Advertise here!
Rockford fosgate 550x mike49504 Car Audio 15 10th June 2011 05:11 AM
rockford 501s one bad channel stoke Car Audio 18 23rd February 2011 04:43 PM
Rockford fosgate 550x mike49504 Car Audio 1 11th February 2011 12:30 PM
Rockford Power 550x bias issue brandes.cm Car Audio 5 24th November 2009 01:13 PM
rockford fosgate 550x mike49504 Car Audio 21 6th December 2008 10:26 PM
