Power Acoustik Bamf4000d  no audio out on master mode
Old 26th March 2012, 09:18 PM   #1
ivkata is offline ivkata  United States
Arrow Power Acoustik Bamf4000d no audio out on master mode
ok got this amp online and acts strange .On master mode most of the time there is no audio out ,but in few times i got it to play when i messed with the volume knob where in over half gain the audio will come up but most of the time nothing.When i sett it to slave i always have good audio but low output 80-100 watts and gain and or other knob adjustments have no effect on the output .I did replaced the volume control with another from a good known amp and this changes nothing ..I don't know is it my luck but i always strike with amps that have some mystery problems
Old 26th March 2012, 10:59 PM   #2
Perry Babin is offline Perry Babin  United States
Look at the DC offset on the output of the op-amps near the RCAs (all of the op-amps in that area).
Also confirm that all of them have both positive and negative supply voltage on the power supply pins.
Old 31st March 2012, 11:09 PM   #3
robbysankar is offline robbysankar  Guyana
sorry to jump on your thread,i have one of these amps and had two op amps that is connected to the input jacks damaged,changed em and she's passing a nice clean audio but as soon as i connect it in the vehicle it smokes r 101,im assuming the value is 47ohms but if not please advise me what it is.
ps.i also double checked the wiring in the vehicle making sure no rca or speaker leads are connected to chassis.
Old 31st March 2012, 11:28 PM   #4
Post #3:
220 ohms.
You likely have a shorted transformer. Disconnect all wires from the amp and measure the resistance from the B+ terminal to the negative speaker terminal. If you read anything near 0 ohms, the transformer is shorted.
I won't answer any more questions for this amp in this thread.
Old 2nd April 2012, 04:33 PM   #5
thanks for your reply
Power Acoustik Bamf4000d  no audio out on master modeHide this!Advertise here!
DAC in Master, CD in Slave mode - How? spavleski Digital Source 24 9th June 2016 01:57 PM
Power acoustik lt1920-2 amp stuck in protect mode psu ishue ivkata Car Audio 15 14th December 2010 03:29 AM
High end Switch Mode Power supply for Audio Petter Parts 29 5th May 2010 07:42 AM
Yamaha Audio Master Mode on CDR MRehorst Digital Source 7 3rd October 2002 12:27 PM
Yamaha Audio Master CDRW mode MRehorst Digital Source 1 18th June 2002 05:08 AM
