Need help making or finding 3 a/d/s bypass x-over module for a/d/s M860
Is this the amp you have?
Thanks for the reply Perry. Unfortunatly I have all the ones you have pictured.
Would it be ok to run my a/d/s x-over module that is set to 65hz and up on my mids since I usually have my active HU crossed at 80 and sometimes at 65hz?
Will haveing two crossovers on each output cause issues? sorry in advance if this is a dumb question.
