Would bridging two 4ohm subwoofers together into a 2ohm channel blow them?
I bridged two 12 inch 4ohm subs unknowningly to an amplifier that wasnt stable for 2ohms, amp overheated, could the subs have blown too, let alone the amp??? |
#2 |
If the amp's ultimate failure mode due to overload was to short output devices it is possible that it put DC into the VC of your subwoofers and that could damage them.
Do you have a DMM? If so measure the DCR of the voice coils and compare to the manufacturer's specification. Be sure to subtract out the meter lead resistance when doing the measurement. A DCR of significantly less than 3/4 of the stated impedance [4 ohms] if the DCR is not given would be a cause for concern - indicating that the VC is probably shorted.
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
| Blown Subs? | adelphia83 | Car Audio | 4 | 7th April 2011 04:02 PM |
| B&W 220i tweeter blown,replacement ?? | gazzz | Multi-Way | 3 | 9th May 2008 12:54 PM |
| Blown Amp? | marob | Solid State | 1 | 14th January 2008 12:12 AM |
| Blown t-amp? | ibbo | Class D | 1 | 6th July 2007 08:50 AM |
| Possible blown amp | derrickg | Car Audio | 0 | 11th April 2007 09:02 PM |
