Punch 500a2 messed up channel - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 21st March 2012, 04:39 AM   #1
Default Punch 500a2 messed up channel
Power was applied backwards to this amp and it took out one channel. I found Q122 and Q123 shorted, those were replaced. I still can't track down the culprit. Here are a couple wave forms. One is from the collector of Q103 and the other is from output (2012-03-20-22-55-30_126).
Old 21st March 2012, 07:02 AM   #2
If there is no DC on the output, connect a dummy load to the channel, drive a sine wave into it and post the waveform on the output.
Old 21st March 2012, 11:56 AM   #3
No dc on the output.
Waveform is missing the lower half. The signal looks ok until Q102 and Q103, it gets squared off.
Old 21st March 2012, 02:38 PM   #4
Does lifting D104 allow it to produce clean audio?
Old 21st March 2012, 03:02 PM   #5
Nope, tried that already.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 22nd March 2012, 10:34 AM   #6
Are the 20 ohm resistors connected to the emitters of the drivers within tolerance?
Old 23rd March 2012, 02:47 AM   #7
seankane's Avatar
If the 20 ohm resitors were bad you would think there would be DC on the channel?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 23rd March 2012, 03:14 AM   #8
Those were replaced when the transistors were replaced. I will double check them.
Old 27th March 2012, 02:07 AM   #9
Back to fumbling on this amp. Q122, Q123, R174 and R175 replaced. Still no lower half of the sign wave with D104 lifted. D104 cathode -37.14Vdc and anode -36.74Vdc. I have -3.8Vdc on the cathode of D204 in the good channel.
Old 27th March 2012, 11:21 AM   #10
Are those voltages for D104 on the solder pads or have you reinstalled D104?
Rockford punch 500a2 chipper Car Audio 45 10th February 2012 01:55 AM
Distorted LF channel on punch 200a4 chipper Car Audio 5 23rd September 2011 03:50 AM
Rockford Fosgate Punch 500x 4 channel seankane Car Audio 48 29th April 2011 10:46 PM
Punch 500a2 distorted channel chipper Car Audio 62 21st March 2011 09:02 PM
Punch 40DSM no output on either channel brandes.cm Car Audio 33 27th June 2010 04:52 AM
Copyright 1999-2017 diyAudio
