Go Back   Home > Forums > General Interest > Car Audio
Old 6th April 2012, 02:45 AM   #41
Hmm, wonder if I should check the .1ohm resistors. Hey looky there, 3 are open and the other 3 read high. Man I wasted everyone's time.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 6th April 2012, 02:07 PM   #42
I guess that wasn't the whole issue, since bias won't adjust unless I lift D104. I also have a full sinewave with it lifted. Something is still tripping the protect circuit. Q116-118, R162 and D105 have been replaced.
Old 6th April 2012, 03:58 PM   #43
Will the amp produce a clean rail to rail sine wave with a load with D104 lifted?
Old 6th April 2012, 04:08 PM   #44
Yes all looks good when D104 is lifted.
Old 7th April 2012, 06:41 AM   #45
Reinstall D104. Remove and then replace the following transistors, one at a time in the order listed. Which one is the first to allow the amp to play when it's out of the circuit.
Q118, Q117, D116
Old 7th April 2012, 12:38 PM   #46
Q118 showed a sawtooth waveform, not a nice sine.
Q117 allowed full sinewave.
sent from an IRFZ48N
Old 9th April 2012, 08:51 AM   #47
Reinstall all of those parts and remove R157. Does that allow the amp to produce clean audio?
Old 9th April 2012, 11:50 AM   #48
With R157 removed I have a sinewave.
Old 9th April 2012, 10:41 PM   #49
It appears that the fault is in the DC offset protection circuit.
Check the following and confirm that you have the ±14 on the diodes.
D103
D105
R127
R129
R130
R147
R156
Old 10th April 2012, 12:10 AM   #50
All check ok, diodes show correct voltage.
With a signal being input and a 3 ohm load Q113 gets hot in a short period of time(about 30 seconds).
Rockford punch 500a2 chipper Car Audio 45 10th February 2012 01:55 AM
Distorted LF channel on punch 200a4 chipper Car Audio 5 23rd September 2011 03:50 AM
Rockford Fosgate Punch 500x 4 channel seankane Car Audio 48 29th April 2011 10:46 PM
Punch 500a2 distorted channel chipper Car Audio 62 21st March 2011 09:02 PM
Punch 40DSM no output on either channel brandes.cm Car Audio 33 27th June 2010 04:52 AM
Copyright ©1999-2013 diyAudio
