Punch 500a2 messed up channel - Page 4 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 6th April 2012, 02:01 AM   #31
Those both seem a bit high. Compare them to the other channel's corresponding components.
Old 6th April 2012, 02:04 AM   #32
Q220 and Q221 1.04Vdc
Q222 and Q223 1.15Vdc
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 6th April 2012, 02:05 AM   #33
Should Q109 and Q111 be back in the circuit?
Old 6th April 2012, 02:21 AM   #34
I think both of the diodes in the other channel are defective. You shouldn't have much more than 2x 0.5v.
If you replace the diodes and the bias begins to work (turn fully CCW before applying power), reinstall those two transistors to see if the amp will produce audio.
Old 6th April 2012, 02:22 AM   #35
With Q109 and Q111 back in circuit I read .998Vdc and 1.2Vdc
Old 6th April 2012, 02:23 AM   #36
D106 is defective or D107?
Old 6th April 2012, 02:29 AM   #37
They both look defective. The diodes are simply two normal diodes in series. I wouldn't expect 1.7v across them. 2.4v is definitely too much.
Old 6th April 2012, 02:41 AM   #38
I replaced D206 and D207 and D106 and D107 and I have the lower half of the waveform now. It isn't a nice sine wave, the lower half is more triangle.
Old 6th April 2012, 02:42 AM   #39
sent from a IRFZ48N
Old 6th April 2012, 02:59 AM   #40
With it loaded the bottom half of the signal is gone.
Rockford punch 500a2 chipper Car Audio 45 10th February 2012 02:55 AM
Distorted LF channel on punch 200a4 chipper Car Audio 5 23rd September 2011 04:50 AM
Rockford Fosgate Punch 500x 4 channel seankane Car Audio 48 29th April 2011 11:46 PM
Punch 500a2 distorted channel chipper Car Audio 62 21st March 2011 10:02 PM
Punch 40DSM no output on either channel brandes.cm Car Audio 33 27th June 2010 05:52 AM
Copyright 1999-2017 diyAudio
