#11 |
Its been awhile since i worked on one of theese can u post a photo of the board and i can tell you what needs to be replaced and give you the part numbers
#12 |
Can I replace c3228 with 2sc2383?
#13 |
#14 |
#15 |
Try replacing the two transistors in the rectangle in the attached photo.
If you have to order them, order both the MMBTA42 and the MMBTA92.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#16 |
#17 |
Post links for the datasheets for the two transistors and indicate where they're being used in the amp.
#18 |
If I remember correctly that is one of the drive transistors in the power supply
#19 |
you must control the smd cap
m:K7 |
#20 |
sorry for the lack of information.
ktc3228 KTC3228 datasheet pdf datenblatt - KEC(Korea Electronics) - EPITAXIAL PLANAR NPN TRANSISTOR (COLOR TV VERTICAL DEFLECTION OUTPUT, COLOR TV CLASS B SOUND OUTPUT) ::: ALLDATASHEET ::: i only suggested 2sc2383 because while searching for ktc3228 it had it as an alternative. I cant find that web page nor do i know if its creatable. Ktc3228 is in q288 location on the board. Pin 1 is tied in with 2 resistors and a cap that leads to the source of 3 output transistors q220 221 222. Pin 3 is tied in with the side of the cap and resistors. |
| Hifonics BX1205D | m4ick | Car Audio | 15 | 22nd October 2012 02:01 PM |
| Hifonics Eagle | Dr Zeus | Car Audio | 3 | 17th May 2011 02:07 AM |
| Hifonics | dtisme | Car Audio | 3 | 7th August 2010 12:49 AM |
| hifonics 1606d | dtisme | Car Audio | 9 | 2nd August 2010 09:17 PM |
| Hifonics Brutus | lee1976 | Car Audio | 3 | 20th July 2010 11:19 AM |
