im working on this amp and i got it to play but the output driver card get really hot then the relay clicks.but the amp doesnt turn off or go into protect.any idea what that could be?
You need to give the exact model number. Even then, more information may be needed because at least one model number hifonics amp had 2 different boards.
The components in a class D amp (except for the output transistors) operate at approximately the same temperature whether it's idling or driving its lowest rated load at full power.
