RF BD15001
RF BD15001
Old 15th March 2012, 08:37 PM   #1
ian33 is offline ian33
Default RF BD15001
hi all
This amp came in with half of the output fets burn.I remove them and power the amp with a limiter.The led on the red and black wire is on,is it for protect?
On the center leg of the rectifiers i get about 38.04 v - and +. Shouldn't it be more that that?
On the twisted red and black wire i get 68.45v
Old 15th March 2012, 09:05 PM   #2
DREW028 is offline DREW028  United States
Send a message via AIM to DREW028
The LED next to the RCA inputs is the protection LED. Power LED is under the RF logon on top of the amp.
Old 15th March 2012, 09:21 PM   #3
ok well this amp is not in protect,but i think the rail voltage is to low
Old 15th March 2012, 11:51 PM   #4
Perry Babin is offline Perry Babin  United States
You should read approximately 100v DC across the red and black wires.
If you're using a limiter and the input voltage is significantly lower than normal, that could account for the low rail voltage.
Old 19th March 2012, 02:13 PM   #5
The output FETs irf 3415 and irf6215 can i used irf3710z in place of one of them
for test?
Old 19th March 2012, 02:37 PM   #6
No.
Old 21st March 2012, 11:15 AM   #7
brandes.cm is offline brandes.cm  United States
Check u21, that fails quite often.
rorrim eht ni kool
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
RF BD15001Hide this!Advertise here!
Rockford Fosgate BD15001 seankane Car Audio 62 9th May 2011 07:55 AM
help rockford bd15001 stoke Car Audio 10 5th May 2011 10:16 PM
Rockford Fosgate BD15001 stuck in protect seankane Car Audio 34 1st April 2011 08:11 PM
Rockford Fosgate BD15001 seankane Car Audio 70 1st April 2011 04:22 AM
rockford fosgate bd15001 mike49504 Car Audio 263 6th March 2010 06:52 AM
