Go Back   Home > Forums > General Interest > Car Audio
Old 15th March 2012, 03:57 AM   #1
seankane's Avatar
Default Rockford BD1500
Have a BD1500 in for repair. The amp does not power up. Nothing looks obvious, none of the outputs or power supply fets seem shorted.
The amp is sending no gate voltage to the power supply fets and it is not producing any rail voltage.
Niether the power led or the protect led light up.
The SG3526N reads as follows:
pin 1: 1.919
pin 2: 0.002
pin 3: 4.98
pin 4: 0.003
pin 5: 13.23
pin 6: 0.003
pin 7: 0.003
pin 8: 13.23
pin 9: 5.01
pin10: 5.01
pin11: 0.000
pin12: 4.24
pin13: 4.68
pin14: 4.99
pin15: 0.000
pin16: 0.000
pin17: 0.008
pin18: 3.703
I believe pins 13 and 16 are my output why the low voltage on 13 and no output on 16?
I have not removed the board yet to see if there is a burned trace underneath just doing some trouble shooting first.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 15th March 2012, 05:33 AM   #2
Confirm that you have 12v on both ends of D14. That feeds pin 17 which is the supply pin for the internal logic circuits for the IC.
Old 15th March 2012, 06:32 AM   #3
seankane's Avatar
I have proper voltage at either end of D14.
Old 15th March 2012, 06:55 AM   #4
Confirm that you have a good connection between the cathode of D14 and pin 17 of the 3526.
Old 18th March 2012, 06:16 PM   #5
seankane's Avatar
I have to remove some of the stripped screws today before I can get the board out. Someone stripped out 4 6/32 screws that clamp the MESHA down.
I will see if there is a break in the connection.
Old 18th March 2012, 08:21 PM   #6
seankane's Avatar
You will have to excuse me Perry I have once again for the second time read my readings backwards on the IC. The Sg3526N reads as follows.
pin 1: 5.01
pin 2: 0.000
pin 3: 4.24
pin 4: 4.68
pin 5: 4.99
pin 6: 0.001
pin 7: 0.001
pin 8: 0.008
pin 9: 3.702
pin10: 1.918
pin11: 0.003
pin12: 4.97
pin13: 0.004
pin14: 13.24
pin15: 0.001
pin:16 0.003
pin17: 13.25
pin18: 5.01
No output on pins 13 and 16. The amp after leaving power hooked up randomly turns on and off for a few seconds when ever it feels like it.
It did this twice then Q2 went up in smoke and full short to my power supply. I clipped Q2 out of the circuit and re-powered the amp.
Did the same thing randomly turning on and off when ever it felt like it but removing Q2 got rid of the short and all the other power supply fets test fine.
What could be causing this!!!!!
Old 18th March 2012, 11:02 PM   #7
Post the voltage on the LM339.
Old 18th March 2012, 11:32 PM   #8
seankane's Avatar
LM339
pin 1: 0.008
pin 2: 0.008
pin 3: 13.24
pin 4: 2.026
pin 5: 1.236
pin 6: 4.37
pin 7: 5.01
pin 8: 0.232
pin 9: 0.230
pin10: 5.01
pin11: 8.26
pin12: 0.000
pin13: 0.008
pin14: 0.001
Old 19th March 2012, 06:41 AM   #9
Lift D20 and D21, one at a time to see if either allows the amp to power up.
Old 20th March 2012, 02:53 AM   #10
seankane's Avatar
I lifted D20 and tried to power up amp with no luck.
Leaving D20 out of the circuit I removed D21 and powered the amp and it powered up fine with the exception of a whiney transformer which could have something to do with one of the power supply fets out of the circuit.
With these results what do you think? What is the purpose of D20 and D21?
Rockford BD1500 seankane Car Audio 11 19th December 2011 03:52 AM
Rockford fosgate BD1500.1 mike49504 Car Audio 18 3rd August 2011 10:06 PM
rockford fosgate bd1500.1 robbysankar Class D 6 2nd July 2011 09:28 PM
Rockford BD1500 seankane Car Audio 19 1st June 2011 01:40 PM
Rockford Fosgate BD1500.1 mike49504 Car Audio 4 17th March 2011 10:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
