Hifonics Brutus BXi1600D does not power up
Old 12th March 2012, 06:19 PM   #11
Mote is offline Mote  Estonia
Never mind.
TIP41C had also broken leg, that was switching amp on and off. After replacing it I can bend and twist and push on the board as much as I like but I can not get it to turn off.
One of the outputs had shorted, I missed it earlier because I measured resistance on the pads of outputs, it was prior to repairing the broken legs. It was one with broken leg so when I checked it there was no contact to the transistor. I missed all the broken legs because I did not want the heatsink compound on my hands and scope wires etc and I wrapped all of the transistors in tape.
I removed all of the outputs, power LED is green. I get nice square on pin 5 of 4080, triangle on pin 6 and squares on pins 11, 13, 18 and 20. I assume that 4080 is working properly.
I order all new outputs and see what happens then.
Tools: Perrys tutorial, C1-76 o-scope, Weller WHS40, Mastech MAS830L multimeter, Mastech MY6243 LC meter, 16A supply
Old 14th March 2012, 08:39 PM   #12
Replaced all outputs, amp is working just fine.
Old 30th May 2015, 01:27 PM   #13
nero9 is offline nero9
Hy
Plese help.
How much of the resistance has R29c?
Completely burned
Old 31st May 2015, 07:10 PM   #14
Sorry, dont have the amp anymore. I have a few other Hifonicses, if I have time, I will take a look, if that part of the board is the same.
From my picture it seems to be yellow-brown-black, 41 ohms?
Old 31st May 2015, 07:36 PM   #15
Perry Babin is offline Perry Babin  United States
Most similar amps have a 47 ohm resistor in that location.
If you have any other questions, start a new thread.
Old 31st May 2015, 08:47 PM   #16
Thanks!
Hifonics Brutus BXi1600D does not power upHide this!Advertise here!
Hifonics Brutus 1206D Dr Zeus Car Audio 4 31st October 2011 02:05 PM
hifonics brutus BXI1500D elev8rsh0es Class D 1 8th February 2011 05:47 PM
Hifonics Brutus lee1976 Car Audio 3 20th July 2010 12:19 PM
Hifonics Brutus BX1500D FireII Car Audio 5 24th May 2010 04:08 AM
hifonics brutus bxi1206d ray9043 Car Audio 2 30th March 2008 06:36 AM
Copyright ©1999-2017 diyAudio
