Diy monoblock 700Wrms/2Ω
Old 6th March 2012, 09:17 PM   #11
ultra is offline ultra
ultra's Avatar
Default audio amplifier section
The audio amp is an existing AB class design, that has been modified.
Also here everything is hand made, starting with the pcb
Old 6th March 2012, 09:26 PM   #12
ultra's Avatar
There are 6 high ripple 3300/100V capacitors, used as bypass to the output mosfets.
The trafos are shielded with a mu metal sheet, as well as the driveer circuit of
the audio amp.
Two following pics are from the older version pwm (sorry dont have any newer)
Old 6th March 2012, 09:28 PM   #13
ultra's Avatar
Since this is a mosfet amp, i used low inductance fukushima 5W resistors to
ensure stability.
Old 6th March 2012, 09:38 PM   #14
ultra's Avatar
Default results
Two things describe this amp :
Speed and bandwidth.
Both pics are taken with the amp fed with 4Ω/1% resistive load, at 37Vp-p.
The small overshoot at the square, dissapeared with a different setting of the
idle current.
Old 6th March 2012, 09:49 PM   #15
ultra's Avatar
and some high frequency tests.
Please note that in all pics the load is 4Ω/1% resistive.
Old 6th March 2012, 09:59 PM   #16
ultra's Avatar
Default power
The output power with a 4Ω load (unclipped) was 119Vp-p (442Wrms/4Ω)
and it reached 123Vp-p (475Wrms 4Ω at clipping).
Efficiency was measured at 410Wrms/4Ω, and was about 56%.
I cant be more specific, as my ammeter is not that accurate (for now)
At 2Ω load the output at clipping was 37.5V, resulting in 703 Wrms.
The consumption was around 110A, therefore Efficiency was about 47%.
Old 6th March 2012, 10:11 PM   #17
ultra's Avatar
In a Greek forum where this amp was presented, i was asked to provide photos
of the amp driving a resistive load with a capacitor in parallel.
First pic is 4Ω with 2,2μF in parallel
second pic is 4Ω with 4,7μF in parallel
Old 6th March 2012, 10:20 PM   #18
ultra's Avatar
For me, i think that the best way to test the stability of the amp
-especially when mosfets are used to the output-
is to drive the amp with a high frequency square signal, unloaded.
The two pics below, show the same event.
In the frist one we see the 100K square frequency,
and when i changed the setting of my scope we see that this is 142Vp-p.
In my opinion, not all mosfet amps are capable of this.
File Type: jpg FULL OUTPUT AT 100K SQUARE NO LOAD.jpg (107.7 KB, 25 views)
Old 7th March 2012, 03:40 AM   #19
1moreamp is offline 1moreamp  United States
Impressive piece of workmanship !!!
Old 7th March 2012, 05:17 AM   #20
ravpreet420 is offline ravpreet420
schematic ?
Diy monoblock 700Wrms/2ΩHide this!Advertise here!
200w/8Ω smps & class d module debugging authlxl Class D 24 8th June 2010 03:30 AM
using an impedance adapter to make an external DAC drive 32Ω headphones? leeperry Headphone Systems 28 28th April 2010 12:05 AM
Yet another monoblock Sch3mat1c Solid State 4 22nd August 2009 12:00 AM
Chassis for DIY MonoBlock Tube Amplifier sgerus Swap Meet 1 20th January 2009 07:40 PM
The best DIY monoblock? christianlie Solid State 10 17th December 2006 01:56 PM
