Adcom car amplifiers question - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 5th March 2012, 06:46 PM   #1
azvrt is offline azvrt  Netherlands
Default Adcom car amplifiers question
Adcom car amps have RCA shorting plugs which must be used according to the manual. It is stressed multiple times in the manual. It does not say why.
Would anyone know why, and more importantly, what could happen when powered on without them ?
I powered on a GFA-4302 earlier today but I might have done so without one of the two plugs, can't remember for sure. Could I have caused damaged ? It seemed to be playing music fine.
Hopefully someone can set my mind at ease, I'm really afraid I might have caused damage ?
Old 5th March 2012, 07:11 PM   #2
The amp is designed for balanced inputs. Without signal on the negative RCA, the amp may not have the right gain or may not be able to prevent ignition noise (guessing at possible issues). Installing the jumper in the negative RCA is like switching a SS amp from balanced to unbalanced.
Old 5th March 2012, 07:28 PM   #3
Thanks.
So no harm done if I accidentally did use it without shorting plugs earlier today ?
Old 5th March 2012, 07:31 PM   #4
Not as far as I know. You can make shorting plugs. Cut an RCA cable, strip it and twist the center conductor and shield together. If you have male RCA connectors, solder the shield directly to the center conductor.
Old 5th March 2012, 07:35 PM   #5
Yes this amp misses one, so the former owner made an extra one himself. As I first thought these plugs were just to cover the unused inputs, I removed the ugly looking self-made plug. I think I tested the amp with the plug removed. Later I saw the plug had the center shorted with the shield, and contacted the former owner that's when I learnt they weer not plugs just to cover unused inputs but shorting plugs.
As long as I did not do any damage, that makes me happy.
Any idea whether these plugs can still be obtained from Adcom. I heard they quit all support on car audio products ? I am also missing a couple of screws for the speaker terminals.
Anyone own any Adcom car audio joesch1999 Car Audio 2 5th January 2011 03:50 AM
Are there really 1000W amplifiers for car? RealForce Car Audio 5 13th April 2010 03:28 AM
car amplifier ADCOM AMP GFA-4402 zuki Solid State 5 9th September 2005 06:24 AM
Need Car Amplifiers Pic's Hi Speed Car Audio 0 27th July 2005 02:11 PM
connecting car amplifiers Aaron Everything Else 0 17th June 2003 01:35 AM
Copyright 1999-2017 diyAudio
