us amp md3d
I got amp friend that didn't take care of it. When I received it 2 caps on the output side were popped and the 2 of the legs on choke had broke. All 24 power FETs are shorter including 3 output FETs.
Power fets are marked irf1010n, will irf1010npbf work? I didn't see a difference other than lead free.
Where the choke leads broke I can't get them soldered back in place . Can I unwind 1 turn and solder it back in?
I called RE audio and asked for the service manual. They lady said they would email it but its been over a week.
The PBF will work.
It would be better to extend the wire instead of taking 1 turn off. In some instances, taking 1 turn won't make a difference. In other amps, it could cause both the inductor and the output filter capacitors to run hotter than normal. I'm assuming that you're referring to the output filter inductors.
